  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paul your lucky :) i actually got more money than i thought so im happy at the moment .... im not rolling in money but i have enough to pay for SAFC ;)
Dad is ordering me to find lock nut to get those brakes fixed too .... so i'll look for that tomorrow .... i took him out tonight in my car and he whinged about my brakes grinding the whole way ..... "u need to get them looked at ASAP lauren" :D
friday next week is my last day .... oh so fat .... oh so horrible ... scary place.
Talknig about the opposite of fat saw a girl on the train i was friends with in primary school today ... i knew her threw out high school too .... i think she's now anorexic ... she looks awful ... like trailer trash or something ugh .... id rather be a little plump than look like that!!
nah she's an "overachiever" and a "square" its anorexia. Yes drugs keep you thin .... why im now so fat. ;)
lol that would be funny me "trying to sort it out" .... could turn it into a reality tv show .... like when paris hilton goes to the country n tries to milk cows .... heres lauren trying to change brake pads without braking a nail :D
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
