  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paul, if they gave me more shifts it would be fine, but cuz im turning 17 soon im getting cut back as it is cheaper to give the younger crew my shifts which is really shitting me and the Head boss just does it so he can make more money, that is why i got 2 get into Closes as only older crew do them
Paul ..... Darrens girlfriend isnt really into cars so i assumed that you had already invited Alex etc and plus i tend to get ignored at car events by you anyway i said the Darren could come with me if he wanted to go poke the piss outta the trevs.
whats wrong with the Commie TJ?
Paul didnt mean to piss you off .... can still come with you if you want but i didnt exactly get an invite from the beginning and its obvious you've already planning to go with others ... thought i would just be a whinging drag.
Niz, im tring but i can't find anything, i really want to get out of fast food. I had my prefect job setup, i was going 2 work at a netcaffee, get good pay and i could do anything will i work (do my h/w for school, play the pc ect ect) but the play close down and i am still waiting for the new one 2 open up again which could be along time :(
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
