yeah well i kinda know what its like .... when i was little my parents used to drag me into the business on school holidays :P obviously both his dad n mum work and they have noone to look after him.
Good job Joe ........ We need scout patchesn badges :)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
LOL @ Whale World .... we could start up our own!
I wouldnt mind going down south to work for a while ....... but not many places sell BP Ultimate & not many good tuners.... so i can put that idea out of my head :P cant have the baby sick!
Going to Motorvation?
NIZ,Bunbury has BP Ultimate , but the only good Tuna is on the fishing boats in the harbour!
I'm trying to get to motorvation on Sunday , The "Handbrake" is working so I'll have the three little Tax deductions!
Taking a 23ft boat to Dunsborough Friday night /Saturday tho ...that will be SWEET
im not LIZ im NIZ .... and yes i am bored. Good one Sherlock .... you've solved the case :P
soiled youre old sheet? actually dont ansewer that question.
Im going shopping at lunch too ..... theres something i want .... but i probably wont be able to find it cos you never can.
Speacking of down south... I am plannig to goto dungerbrough end of the january... I really Need to get away have my JOE timeout time.
all me mates telling think about it but I definately Going WITH or WITHout them.
so if some of you if time permits, there you are welcome to come along... looking at the last week of the january 25th weekends or 1st of FEB
I just have to find damm 4WD car to get there lol
cheers
Joe
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
