  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Mikey has shrinkage :D
Tom .... yeah know the story .... cops are having a yellow spree again .... Adrian has one too.
I saw so many cop cars on the way to work today ...... i took a corner fast .... then i see on the otherside of the road a cop bu the was buried in traffic so nothing he can do about it .... 3 minutes up road i see another cop. Paranoia :Paranoid:
at 17 i was living like a 20 year old anyway .....from 16 i was living like a 20 year old so its not like i can really say those years were any different to now except i would like to think im slightly wiser now.
When i was 17 i was told by mum i had to be home by dawn one night when i went to a party ..... i didnt make it home by dawn ..... i was in so much trouble cos i left the mobile in car and couldnt hear her ringing me and leaving nasty messages.
Only difference between then n now - is i dont have to be home by dawn :D
This site looks abit munted in Mozilla on a Linux OS... will have to stuff around with some fonts I guess... Anyways...
Helping people;
I jump started a car as recently as last week, and when some chick ran outta gas in the worse possible place (on a highway between motorway onramps) myself and another guy pushed her beastly Pulser out of the way (which was afarkin long distance) and then took her to petrol station and back, but would I stop if I saw a road rage type deal... no I wouldn't, but I would at least phone the cops.
Hourly Rates;
$40 per hour for cleaning? I think your wee bit overpriced as domestic cleaner is about $15/hr from memory, but I have made about $50/hr for car detailing... bump up ya rates and specialise :D
R33 Interiors;
I've seen one with all leather interior, and a friend started to do the white leather bit on his before he rolled it (5 or so times, ouch), I might still have afew pics around....
Age;
I'm older than you all... except maybe Dan_The_Man who claims to be prehistoric :)
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
