  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
How much for these coolers :aroused:  :aroused:
Don't know atm, only have prices on some of the kits but they are good and the mounts etc are very proffessional.
All the piping is done in moulded silicon in blue.
Looks smart.
Jill ( jill200sx on Silvia WA ) has one and is a good fit.
Cheers
ken
oo dat one. are u gonna turn it into a monster like he did 2? hehe
sub- i don think uve met ken before
Will be a sort of shop car/development car.
Will be doing a budget RB30/RB25 headed build with custom exhaust manifold and terb.
Have the GReddy plenum and will chuck in a PandP wolf. Hope to get around 400 at the treads but with strong midrange and good driveability.
Once its refined we will then sell the drive/drive out package.
Cheers
Ken
Only need cooler no piping ... we make our own pipes in stainless :)
What size , I will get a price?
They guarantee it will outflow a hybrid and are as good as any Jap brand one.
Cheers
Ken
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
