  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
its all depends...
its just like your car... all depends how you treat them, you wil get it out of it :)
think about it
Thank you Joe .... finally someone realises you get what you give :wave:
Thanks for congrats Aidiwn!
