theres a jetty at east perth .... who wouldve thought? ..... Joe ... master photographer! .... hmmm pity you cant get closer to a backdrop of kings park :)
Black is best Aidwin .... everyone knows that ;)
yeah you can... from over the bridge... narrows.
yeah you have to stop in the middle of the freeway, but it can be done...
I done it once when I had my car ages ago like 3AM in the wensday mornig :wave::
but it cane out :thumbdwn: damm film cameras
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
aidwin it was probably one that Dan saw and mistook for your car!
I gotta clean up the gallery some doubles cos of posting probs but will do it later.
Too many cars look like mine ..... wanna know where my phucking veilside wing is!
difference between you n i Mikey .... is daddy dint buy what is under my bonnet :wave:
Hp means phuck all on the strip ..... dyno maybe you would beat me but 1/4 is not only the car .... but your driving.
yeah you cant engine brake unfortunately ..... but Rep has given me the formula to unlock the power of the auto ..... and really it can be done quite cheaply .... im surprised!
What parts of your zorst are you looking to sell Aidwin cos Ouch has offered me his but he's not sure he's gonig to sell yet :wave: and i have a list of things to be in by mid feb .... zorst is one of them.
well for a 17 year old that apparently just bought a Skyline and works at Maccas you dad is either giving you money or you are drug dealing on the side .... sorry but yeah its not hard to see thru that.
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
