  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
talknig about alarms n such .... i walked past a passed out abo on the footpath in the middle of east perth today ..... kind ajust stepped over him ... girl by herself helping anyone is not good ..... and there was a drug rehab centre across the road that wouldve helped him. See i park in that kinda neighbourhood yet dont have an alarm.
Coilovers are only good for track use .... if you told your dad they were neccessary then you conned him .... in fact they make your driving under normal circumstances just more uncomfortable.
What are you going to do for a barrel then Aidwin?
thanks paul :aroused: ... early finish tonight :wave: im going to get lock nut first thing in morning ... brakes alas are getting worse .... and car not starting as easily *sigh* time to trade it in for a honda ...... NOT!
Paul, u r the man i need 2 talk 2.
Only 1 stuiped question 2night;
My front bar is crack pretty badly, now should i fix it myself or get someone 2 fix it? (i have already work out someone 2 respray it so thats all find)
And if i need 2 get a shop 2 do it wat place do u think i should take it 2? Ken said $60 should all they charge me true?
thats the thing ... sometimes it starts fine sometimes it doesnt .... i used to think it was time of day cos on the hotter days it seemed more difficult than cold starts .... but this morning it did it to me after interview .... embarrassing :wave:
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
