Originally posted by gtrken
hey psiker , is Zeldas still the dive it used to be and is Kevin Mann still running it ?
Cheers
Ken
i think its still owned by the same guy.
zelda's wave rocky hotel and liquids all on the same road are now owned buy the same guy. they are all sh1t holes. and closed down the only good club in rocko, the marakesh, saying ot took business away from them
Psiker
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Night earlybirds.
Nice zorst on the ricer Ken? Louder than the one on my car?
the one off the ricer is on the racer now and visa versa.
I reckon it is louder , real cop bait. Don't know whether to swap it back or not after compliance.
Cheers
Ken
Originally posted by Psiker
and the talent at zeldas is appalling. im too afraid to go in there. i think they need better looking gurls for a strip club
Psiker
Ohh , I thought those photos you were posting WERE from the strip club.
Cheers
Ken
Cheers
Ken
depends i find with loud zorsts the cops seem to leave u alone as long as ur doin nothing stupid. they kinda overlook it :P
depends on the policeman u get though
Psiker
really what model r32? i didnt even realise hey. i was thinking old sprinters etc :P
Psiker
1988 was when the silvias first came out and 1989 was the first R32 and GTR
Also can bring in GQ 1988 patrols atm
Cheers
Ken
Cheers
Ken
Guess that means we can't call you Silent Ken anymore:D
Does this also mean that you like the loud zorst - hence you may not change it back?
Guess that mwans we can't call you Silent Ken anymore:D
Cos it's not my daily driver , I don't mind it so much.
Gets a real drone though, but the cannon style out the back and the crackle thru the non cat is cool.
cheers
Ken
Guest
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
