Originally posted by Micko
Ken - twas similar to the cruise we went on when you first introduced me to my R - I remember getting out at the dam with my legs shaking & the smell of burning brake pads:bahaha:
Ahhh yes , the Chris and Ken's Kalamunda to the weir thrashfest.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My speed cut is still in as well - sucks eh?
yeah?
so how come I hit XXX+5 and had long-forward-neck and then you belted past about 20 kms faster?
I might have taken my foot off at that stage, but not by much!
there was one point when we got stuck behind that 4wd and the car with the canoe on top.... I was fuming! but then we went past that multi and Im sure had I not beendoing 55, I would have been doing something horrifically not-55!!
Originally posted by GTS-t VSPEC
Ken, Not a problem for me, I'll sleep with you:p
On the way home after dropping Aidwin home I was driving enthusiastically at the double ton, hard to swerve left and right to avoid traffic, then the car died, I will still doing a ton and a half! Luckily it was in a straight line. Was it just fuel starvation from the sideways action?
See'ya:burnout:
Died ?
As in rolled to a halt , sputtered once , dash lights came on ?
Be more specific.
Cheers
Ken
Originally posted by zanda
yeah?
GTR's seem to get 200kmh before the limiter comes in.
Cheers
Ken
neo
car has tein coilovers with dodgy-install usingone spacer instead of 2 to try and make it lower!
when it came in it wsa on 35s and was the lowest skyine Ive ever seen. pimpin only - cause you couldnt turn the wheel past 5.
have jacked it up about 5-6 inches to put it through the pits.
now seek to arrange a "compromise height".
Died, as in battery and oil light came on, had to re-start the car while rolling at 150:D
See'ya:burnout:
why didn't you just bump start it ?
Sounds weird, sure you havn't got a loose terminal or something ?
How much fuel was in the tank ?
Cheers
Ken
Aidwin,
I think I still need to sort out my brakes, even once hot there not that great:p
See'ya:burnout:
Brakes , biggest killer of speed.
Trouble with good brakes is they cost.
Go DBA slotted , Castrol srf or AP660 brake fluid with a good bleed and Pagid blue pads in the front with Bendix ultimates in the rear.
Adjust the brake pedal height to take out 90% of the freeplay and viola"
A good brake you can trust.
Cheers
Ken
Guest
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
