Miko,
Seems a few dudes got PB's.
I took the Volvo out for a spin tonight, it tells me it wants to go to the drags too.
From the looks of things it will get a mid 14 if I leave it in 'D' maybe a bit quicker. I'll have to get the shift kit put in so I can get 1st to 2nd working better on manual shifts, then it might get a 13.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yea - it was interesting cos some of the guys didn't think the track prep was very good so mixed feelings really.
be interesting to see how the Volvo would actually go - I know it's quick. Would be great to see the look of ppl's faces when it rolls into the staging area:)
I was a bit pissed at first, seemed like I just wasted my money last night, but on the way home I was happy again, beat a few cars:D
There was a Commodore trying to keep-up around a corner, he fish-tailed it a few times before running it up and embankment at 70km/hr:bahaha:
See'ya:burnout:
Should be tomorrow - but as long as it's before next weekend i don't care.
Did you check the map for your cruise? Long term forecast says it may be wet next weekend, but the bbq spot that we checked is undercover - I will phone tomorrow to see if we can book that spot.
excelent idea hopefully we can book a site thats undercover
Guest
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
