  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
when it just idle in my driveway (after i take it for a run and i am letting it cool down) i can really smell it :D
* Sigh *
Hi Mike.
As has been told to you by numerous people, get someone to look at it.
The diagnosis points you have given are not descriptive and definitive enough to pinpoint the exact problem ( and why would a qualified person spend hrs on here trying to anyway )
It could be anything from a faulty reg , split hose, leaking injector, filler neck incorrectly fitted ( my guess as I told you before ) , MAYBE running rich, bad plugs, and the wrath of god ( well maybe not the last one )
As has been explained to you before , rather than ask 15 different people at 20 different times , which pisses everybody off cos you get there advice and then ask someone else , go to one person , pay the money and get it sorted.
BTW if you smell fuel is cos it's is unburnt or leaking which is RICH , not LEAN.
And in case you missed the post from 2 nights ago , all ulp cars run black exhausts.
It was the lead that caused the grey colour in the pipe
Cheers
Ken
Ken- its good,im enjoying myself alot with the food and entertainment heheh. But the crazy drivers is another thing, nearly got rammed
yes read paulie's msg
That's good , when you back and are you bringing a swag of GReddy plenums with you for under a grand. lol
Cheers
Ken
Guest
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
