  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
thanks ken - well the alcohol definity helped the smiling part hahahy by the end of the day my face was sore from smiling hahaha
Bet you were sore in the morning( the feet Troy , not what your thinking , dirty boy :( ) when the affects of the booze wore off.
Cheers
Ken
Cheers Ken.
Got pics from a guy selling front pipes & the pipe is much longer than what mine are & have the hole to mount the oxygen sensor. My front pipes are very short with the oxy sensor mounted in behind the cat.
Just curious to know whether my cat is further forward than normal or if it's cos there is a difference between the 32 & 33?
Cheers
Ken
hahaha I was thinking something dirty when I started reading that hahahaha. Yeah I was a bit hungover but nothing a full buffet breaky didn't fix!!! hahaha
Originally posted by Micko
Cheers Ken.
Front pipes , you mean the bit from the back of the turbo that does a 90deg bend or the two pipes that come off those and join into one before the cat ?
Cheers
Ken
You posted earlier that your dad paid for honeymoon somewhere. Have you been and are back already .
Cheers
Ken
Guest
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
