Hey guys,
I swear theres already a thread on this for WA but where it is i don't know.. So i'll just ask again :D
My R32 is just getting registered, and once ive paid for all the little things i'd like to have the numerous chips and scrapes done as well as having a small break in my sideskirt repaired.
So I was hoping you could all reccomend your favourite shops. I need to be able to trust them with my car as I will be out of town while its being done. Also price is a consideration so not too cheap or expensive!
Thanks guys,
Blacky
https://www.sau.com.au/forums/topic/88276-reputable-panel-shops-in-perth/
Hi Blacky,
I've used Jeff Elliott's Auto restoration (white pages search for 'Jeff Elliott' will turn it up) in the past.
They have been really really good. Good pricing, and the quality of their work is superb. One of my mates did up an old holden torana. Black and yellow paint job. Looks a million bucks. They also completely seam welded the engine bay. really complete job.
I'm about to take my new r32 GTR to them to have some rust repaired and some minor body work fixed.
Cheers,
-Shaun
Dont go to a large place in bently there are well nown but they did mine and now my boot leaks heaps of water and they put 100kms on the clock no s*%t
thats why you leave a note on the dash saying Ive taken the km's down....BIATCH! :P
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
