If you wanted a GTST, wouldn't it be cheaper to just trade in your GTS and buy a GTST than try to do a turbo conversion on it? It's almost like the auto to manual conversion dilemma.
"Games don't affect people. If Pacman affected us as kids, we'd all be running around in darkened rooms munching on pills and listening to repetitive music."
My car wasn't a GT-T or a GT + turbo...it was art! :)
Seriosuly though, my GT + t would whoop my current stock R34 GTT, the power delivery of the high-compression was scary, I'm in the process of modding the GT-T, so it will be interesting to see if it actually gives me the same "fearing for my life" feel that I had while changing lanes in the GT + t
I did the bolt-on about 2 years ago, it was pretty economical back then....I'd probably reconsider now, especially as it made the car so attractive for thieves :)
  • 4 months later...
Everything is stock except the 17inch rims i bought the car with.
Another question...
Its a stock GTS25 4 door, 5 speed auto, I didnt want anything overly fast because im still only 17. I figured it would be a good car to learn on. So what are some good mods to start with and slowly build up. Keep in mind I have a limited budget and a new P plater.
Can I get some good power out of an auto RB25DE?
Im thinking my first mod would be to stick in a k&n panel filter and an exhaust system one i got the cash. Sound good or shit?
By the way I havnt put in the turbo yet, comes later.
Thanks, ciaoz
You're a new P-plater, with a turbo?
How new? :D
  • 1 month later...
My car is non turbo but is complied in japan as a turbo car so I have to do a turbo conversion before I can get it complied here as it has to be stock.So I guess I have a non turbo gtst.Doesn't worry me though cause I want to turbo it anyway.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
