I have got the PFC boost controller kit ready to install.
Would there be any benefit to fitting a HKS wastgate actuator as well?
I will be looking at setting the boost level at about 0.8 bar (12 PSI) which is within the recommended range of 0.8 - 0.9 for the HKS actuator.
Will it make the boost more stable? Make it easier for the solenoid to do its job?
Enable boost to spool up quicker?
Or will the boost controller do just as good a job with the standard acuator.
This is for a R33 25t series II
https://www.sau.com.au/forums/topic/88571-hks-wastgate-actuator-any-use/
sorry to hijack... but where'd u find one and how much?
The actuator? Nengun sell them for about $170 Aus but I can get one from a guy over here in NZ for $150NZ (he wants to get rid of it because he doesn't need it)
The actuator sets the minimum boost pressure so it needs to be rated at whatever minimum you need . Electronic control is good for solving boost creep problems but cannot regulate at less than the spring pressure in the actuator can , only more . I would use the electronic control before the higher rate actuator .
Cheers A .
Cheers  A .
Thanks Disco, so no point in both (I already have the boost controller)
Didn't Sydneykid write something about how to use an adj actuator and ebc together properly?
Found it:
A boost controller solenoid works by opening (bypassing) and closing rapidly to limit the boost the wategate actuator sees. So you can have say 15 psi but the wastegate actuator only gets say 10 psi.
The boost controller also works when you are trying to steepen up the boost curve by keeping the wastegate shut longer. Some are rated at 10 psi but start opening at 5 psi, some people call this \"boost creep\" which is not strictly technically correct.
The problem with all boost controllers happens when you have a big difference between the initial opening psi of the wastegate actuator (say 5 psi) and the boost controller (say 15 psi). The solenoid has to work very hard to bypass this much pressure.
What we have found works well is to increase the pressure of the wastegate actuator. A stronger spring, lengthening the actuator rod, spacing the actuator away from the turbo body or using a higher psi wastegate actuator (eg; a RB20DET actuator on an RB25DET) all achieve this.
If the wastegtate actuator is now say 10 psi, this means the solenoid (still 15 psi) only has to bypass half as much. This results in much better accuracy of boost control.
Edited by Scooby
Not wanting to hi-jack, but since we're on the topic of wastegate actuators, can someone tell me which HKS wastegate actuator (ie. 80mm or 100mm) is more suitable for use on a HKS2835 ProS on an RB25det? Looking to get around 275rwkw with supporting mods (incl EBC)
I wouldn't have a clue which one is more suitable...
Thanks guys :blink:
Thanks Scooby, SK's on the money as usual
Still not 100% sure whether actuator will be much use to me.
If standard actuator is 7psi and I want to run 12psi
(HKS actuator is 12 - 13psi)
is that a big enough difference to reduce the accuracy of the boost via the EBC?
Edited by SAMFISHER
Mate that's a good question, presumably if you set the ebc at 12 psi and the wg at 11psi you'd have an ideal arrangement but I see your point re how much difference is ok to run with - why mess with another peice of adj kit if you don't have to. Hopefully the learned one (TLO) will surface soon...
Cheers
My 2530 arrived this morning and the HKS actuator that came with it has a softer spring than my old rb20 actuator.
How do you set the actuator rod preload?
My rb20 actuator rod had about 3mm ie the rod was 3mm shorter than the distance from the diaphram at rest and the pin on the closed wastegate arm but my 2530 came set up with about 6mm of preload.
Is there a proper method of setting this up?
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
