Hi ,
Just wondering if anyone out there is interested in purchasing some GT-R prints?
The images come from Dino Dalle Carbonare in Japan. You would have no doubt seen his work in HPI and DriftBattle mags.
They are approx:30 x 20 inch (760 x 500mm) and are printed on photographic paper (not some dodgy inkjet, quality LED printing), they come unmounted, delivered in a postal tube. Also have a few JGTC images available.
These will be the start of a new range of automotive prints from my business.
The cost will be $80 (incl. GST) + $5 postage and handling. I need to have some idea on numbers before I proceed with a print run.
PLEASE NOTE: Price change to $55 + incl. GST plus postage of $5. I need minimum of 20 orders of print for this price. This is a SAU price only.
Message me to register interest.
Thanks
Edited by gtrtech
https://www.sau.com.au/forums/topic/88637-gt-r-prints/
If any of you want them framed or block mounted give me a call (Family business)
You're just the man I want to speak to then Guy!
I have some framing I have been meaning to do for a while, and also a pic I am having blown up to get done as well.
Will talk to YOU soon!
https://www.sau.com.au/forums/topic/88637-gt-r-prints/#findComment-1602506
DITTO!
I bought a Japanese waterpaint original when I was in Malaysia 5 years ago, and it is still waiting to be framed.
https://www.sau.com.au/forums/topic/88637-gt-r-prints/#findComment-1603306
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
