Wondering if anyone is up for a cruze / drive on Sunday ??
Unfortunately, missed this weeks installment of Team Westside cause I accidently drank too many beers at a BBQ Sat nite... he he.
Anyways, post here if interested....
https://www.sau.com.au/forums/topic/8864-anything-doing-sun-19th-jan/
You want a hand ?? I'm a pretty good manager, I can tell you all what you are doing wrong !! he he (j/k). :D
Mate, I'm just stinging for a bit of a drive - Maybe a late arvo run down to Brooklyn and back ?? Or Berowra via the National Park from Turamurra ? Just nice and leisurley (sp)
Well, I know it's a bit late....
How about N.Beachs ppl meet at Burger King , Terry Hills at 6:00. Other's meet at Berowra Mobil (LHS going North) at 6:30.
Cruze to Brooklyn & back via OPH.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
