Are you going to keep your mid ninteys R33 for the rest of your life are you? If not im sure you, like me will one day want to upgrade right? hence id want a newer import... and id want to be able to do it with a little hastle as possible...
THATS why the new scheme is a big deal.
https://www.sau.com.au/forums/topic/8881-new-import-laws/#findComment-131032
car prices will always go down.... its just the way it is... sure with the new laws the might hold for a lil bit... maybe even go up a touch... but the bottom line is pricese will always decrease...
Oh and im going to lease my next import through the business :D
hehe
I do get what your saying though.
https://www.sau.com.au/forums/topic/8881-new-import-laws/#findComment-131046
well it's a big deal for me cos i want to import a R34 GT-T in about 7-8 months. Luckily R34 compliance costs are already fairly expensive, and it won't go up too much. But i have to find a mod-free car as to avoid the extra costs of removing them all. Plus the whole process is apparently going to take longer, quite a bit longer.
don't baby our automotive industry by pratically killing off the import one. Make it easy for cars to be imported, give ppl the choice when it comes to buying a car. Let them find out there are better cars for less money, then let the car makers in australia catch up to world standards. Be pro-active rather than re-active. In the long run it will be worth it bcos australia will be producing world class cars because they were forced to catch up due to relaxed import laws.
/end bitch about government.
https://www.sau.com.au/forums/topic/8881-new-import-laws/#findComment-132698
my thoughts from another place - i signed the petition last year
Originally posted by zdeno
i dont understnd
wont the laws increase the prices of our cars??? and it wil also hold there value
i kinda like the new laws
Perhaps it will increase the resale values - but I signed it to help the guys who are trying to get a car [now]!
And what if "we" want or need to buy another car, are you happy to pay perhaps, several thousand dollars extra for what will essentially be the same car passing through different legislation [red tape]?
Some of the laws have already wiped out small business' which can be seen as good for some while bad for other's.
Good: stops the dodgy operators bringing in crap cars?
Bad: too costly for [the honest] small business to adapt / meet requirements of new RAWS?
It all depends on how you look at it i guess, maybe we don't really know what the full effects are yet?
https://www.sau.com.au/forums/topic/8881-new-import-laws/#findComment-133076
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
