Suspension/handling Specialists....
Hi..i'm wondering if anyone can recommend workshops and mechanics who know their stuff on fitting and setting suspension and handling setups, i.e coilovers, camber,castor, toe fitting and settings, for skylines?
Anywhere within about 30kms of brisbane.
Any info will be greatly appreciated~
Thanx~~
https://www.sau.com.au/forums/topic/88958-suspensionhandling-specialists/
i won't be using mercury again for any of my work, but each to their own. However, if you do use them, get someone independant to check after they're finished
I use Shaun at Goodyear Strathpine... great guy and pretty switched on, does top work etc.. he races an Evo in some form of rally so he know a bit about what he's talking about :D They're also a Fulcrum Queensland dealer.
Thanx people fer all the info...fulcrum? do they do tests on used coilovers? im basically getting a set of used coilovers and wanna run a test on their usability, and also if there is any leakage and other problems before buying and installing them at the same time. Will these tests be expensive if they are available?
Murcury are not suspension specalists, they get all their alligment / set up work done down the road at fulcurm, they are quite happy to fit suspension parts though. In my opinion it would be better just to go to fulcurm in the first place.
Accurate suspension. Timms court :)
They seem to do good work, just I think you need to say I want this. Not ask them what you need.
Other than that try and track down Scotty, I think hes over redlands way now.
Actually they go to quickfit on enoggera road (the one next to the mobil).
Or how about www.shockreco.com.au. They can rebuild anything. I had my standard struts rebuilt 2 weeks ago and couldn't be happier with their work.
-rb25
Not since Scotty left, I wouldnt go back there.
Not knocking their work, but hold on to that reciept, and check those shocks on the 29th day after the work was compleated. Rebuilt coilovers apparently only have a 30day warrenty.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
