Hi...Anyone here using or have used Ohlins coilovers before on a r33 gts-t? Got some questions on them...
Cheers~
Yep, I have used many sets of Ohlins in numerous race cars. What type are you talking about? The genuine Swedish Ohlins or the ones made in Japan under licence? I have modified a couple of sets of Jap Ohlins, lowered the springs rates, increased the height adjustment range etc. I have a set of R32GTR Jap Ohlins that I am working onright now.
So please, ask away
:D cheers :D
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1607832
I can't say I've used the car stuff, but have run the motorcycle stuff in a number of roadrace and MX bikes - it is the TOP of the game in that field. If the car stuff is anywhere near the quality of the moto stuff, it should be very good gear.
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1607963
I have Ohlins coilovers in my R33 GTR. Came with the car but suppose to be good stuff worth 5k?, damper adjustable via allen key up front and a black dial behind the rear wheels. Considering changing to a set of Eibach springs.
macattack: did you notice any difference swapping from the springs with ohlins to eibach?
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1608083
Ferni & SK,
When I bought the car I was able to purchase a second hand set to replace the OEMs.
The Eibachs were already installed on the set.
I am not sure of the spring rates but it is a real nice inbetweener. (No doubt SK you could tell me where to check).
Not too hard not too soft. I find the rear lifts a wheel occasionally on the track so I will need to soften the arse slightly but all in all they are pretty bloody good.
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1608244
Yeah, still plenty there. Mainly on hairpin corners, I tend to come through on either 2 or 3 wheels, then light all four up on the exit.
My guess would be insufficient front anti roll or excessive rear anti roll. What size stabiliser bars do you have on it?
:) cheers :)
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1609034
Well i'm looking at a 2nd hand set but i dunno the model and specifications on it...the longer ones are the rear yeah..those have a knob down below which can be turned presumably fer rebound rate i heard as there is a "H" and "S" on it which i guess stands fer hard n soft..then the knob on the top of the coilovers in the middle..what does that tune? i heard its the compression that is adjusted thru that...the weird thing is that the front coilovers from the same set don't have the knob down below and just the knob up on top..is this normal? does that mean the front coilovers are non-damper adjustable? And the height, is it adjustable thru the same way as like TEINS? cuz it doesnt come with any tuning fork...
Pls advice~thanx!
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1609509
SK
Stock!!
What would you recommend?
Ahh, that explains it.
I would go with the BNF27XZ (24mm) on the front and the BNR26XZ (24mm) on the rear. You can probably get them at the Group Buy price of $219 + $20 for freight. That will include an additional hole on each arm for extra adjustment. PM me if you are interested, other details are on the R32GTR/GTS4 Group Buy thread.
:P cheers :D
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1610299
Pls advice~thanx!
The knob at the top on Ohlins is for rebound adjustment, it adjusts the valving via a shaft that goes down to the piston, inside the main shock shaft. The knob on the bottom of the rears is interesting, that would normally be for bump valving adjustment. But I never seen Skyline Ohlins with that feature. Some pictures would be handy.
:P Cheers :D
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1610317
My 32 GTR came with ohlins set up with RSR springs. The springs were too stiff so i put in whiteline spring set.
the shocks are too stiff for sydney roads though, must be the valving.
the front shocks have no adjustment but the rears have a H, S dial on the side of the tube.
They r made in japan.
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1611050
:P Cheers :)
I'll try to get some photos tonight.
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1611533
WOW! Circlip height adjustable rear Ohlins, never seen them. What do the top adjusters look like? And the fronts?
:O cheers :)
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1612638
Top? i dunno never had a look didn't know it would have a setting on top of the rears, i assumed the black knob was the only adjustment?
The fronts are hard to get a photo off without taking the wheel off - but they look the same except no black knob. same circlip adjustable hight, with an alen key under the bonnet on tops of the shocks. Do you want more info or photos?
DO you think i'll have an adjustment under my parcel shelf on top of the rears? i've tried to get my parcel shelf out before but it was way hard so i gave up (aftermarket parcel shelf).
https://www.sau.com.au/forums/topic/89020-ohlins-coilovers/#findComment-1612682
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
