Im looking for an R33 and i found this on Carsales. Just wondering if anybody knows anything about this car, its history or if it seems like a good price for the year and modifications. If theres anything that you want to say but not post please PM me. Thanks for your help.
http://carsales.com.au/pls/carsales/!c...rch_distance=25
https://www.sau.com.au/forums/topic/89060-is-this-r33-a-good-price/
It LOOKS ok, but you will have to see it in the flesh, give it a good look over and take for a test drive. Then you may be able to form some opinion on whether it is a good price or not. Impossible to tell from what is written there.
Agreed,
It's also freshly imported, so he's trying to make cash.
Another thing to check... there's normally a reason why Japs respray cars.... make sure you check for accident damage / rust very very very carefully.
yeah mate there is sum really good importers around sydney also in thornton in newcastle.......
:) i got mine 33 from Australia Compliance Workshop in Thornton, Newy.. friendly service, cheap prices.... too much to mention... ask for Ron (the owner) and tell him the guy who bought the black 33 a month ago referred ya :(
:)  i got mine 33 from Australia Compliance Workshop in Thornton, Newy.. friendly service, cheap prices.... too much to mention... ask for Ron (the owner) and tell him the guy who bought the black 33 a month ago referred ya  :huh:
Lol yeah i went to Rons last week. L Plater 33 went there with me he's just trying to be a cunny funt, its where he bought his 33gtst too. While he was on his L's (cough parents are wogs cough).
Yeah he had a nice 96 series 2 with 18' Volk racing rims, kit, cat back and wing and it was 19500. Had a Apexi power FC too, but it didnt run as well as my mates, meaning it pulled nowhere near as hard. All that my mate has extra is a HKS front mount, pod and CAI. Should there be that much of a difference because of these modifications?
I was thinking the poor performance could be due to the tune done in Japan. RX engineering quoted me $600 to tune, plus i would have to buy a second hand hand controller cos it got ripped during transit, so that went a bit past my budget. They said they are a pain in the ass to tune and require around 7-8 hours dyno time to get a good result, apparently a lot of load points or something?
They recommended (i think) a Microtech, priced at $1400, plus $200 for a tune, again going past my budget.
And it also had a drift gearknob which worried me.
Security, yeah thats cheap but you lose a fair bit from auto, plus the year and kms.
EDIT: and im guessing it looked nothing like it does in your pic it looks awesome atm
Edited by Lukeisbuyinga33
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
