MASSIVE UPDATE 24/4/06 !! !! !!
LOTS OF RANDOM PARTS, - WRECKING RB20DET - CA18DET - TURBOS - INJ - AFM - SENSORS -
RB20DET $
bare rb20det head 100 firm- very good condition only apart as bottom end had bearing noise
plenum 45 - fuel rail and six injectors included
rocker covers 30
throttle body 25
270cc top feed high impedence injectors $5 each or 6 for $20
cooler 20
rb20de exhaust manifold (non-turbo) - $35
CA18DET $
370cc inj 40
intercooler 20
dump 5
f/pump 15
mirror 45 - works fine, drivers side black
calipers X2 $25 - 2 spot calipers, lines, free pads and rotors (just no RWC)
contact : shaun - 0403155282
------------CA cooler---
------RB20 plenum---------------RB20 TB----
------RB25 rockers---------------Rb25de manifold----------T28 blown seal
Edited by shaunr32
https://www.sau.com.au/forums/topic/89228-wrecking-rb20detstock-ca18det-parts/
  • Replies 43
i have no pics yet as i have no cam. they are a factory option 10 stack sony and 6 stack adzrst with head units to suit. no head unit to stacker cable. all working when taken out and if they do not work i will give your money back minus postage or whatever.
where are you located
$50 per one item or $50 for all stez items
shaun
hey shaun,
you wouldnt happen to have the cold start control valve for the RB20DET by any chance at all would you
Thanks in advance
Sop
Edited by RB20SX
sop - what does it look like - i will have it. its yours
i am wrecking the engine that i was going to sell you - it blew up, just as well i gave you the other one. how is the rb20sx going??
killemaul - no ac compressor - soz
pics will be up tomorrow - i finally got a digi cam !!
shaun
tomorrow is now today and the new pics are up.
just to add i do have ceffy center console and handbrake
and a few of the prices i have had to make up so the mods dont get me.
make an offer on anything - the worst i can do, is tell you to go --<<bunch of flowers>>-- yourself in the arse
cheers
i am sure they are identicle, as i have the rb20 turbo manifold on my rb25 at the moment, waiting to be registered with rb25 then i will be selling it in about 2 weeks
ill let you know
sorry for the whatever
shaun
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
