unless you press the reset button at the back of the PFC, or there's a possibility if you take it out for extended period then it may reset itself, but I haven't tried that out yet...
the unit should have a backup battery inside to store all setting (like your computer motherboard remembering what date/time after you turn it off). Eventually the backup battery will run out of power if not on the car for too long.
https://www.sau.com.au/forums/topic/89234-power-fc-qs/#findComment-1611035
Can you write down all your settings as a back up.  Just wondering iof you can get to all of them via the handcontroller..?
I'm getting mine tuned by datalogit - wondering if I could get the map off the tuner in case something happens..
you can use this method however datalogit can access some of the tables that the hand controller does not allow you access to, such as airflow voltage ramp table so you can't back that up. but you can certainly copy the ign and inj maps as a last resort backup
https://www.sau.com.au/forums/topic/89234-power-fc-qs/#findComment-1613023
There's a bloke a rx7 forum that is developing a piece of software similiar to the datalogit.
I've had a play with it and it looks much better than the logit.
He is currently working on a Nissan version, I believe he has completed the honda and rotor versions.
His software uses his own cable, the software is also compatible with the datalogit cable and genuine apexi cable.
It looks very promising.
EDIT: The software is able to open data files from both the datalogit and the genuine apexi fcedit or what ever its called.
Edited by Cubes
https://www.sau.com.au/forums/topic/89234-power-fc-qs/#findComment-1616714
yep pretty much as cubes said, here ive just done a pics and colllection of urls for it if you wanna have a looksy, the guy has done some awesome work.
http://members.dodo.com.au/paul/productinf...une/page_01.htm
https://www.sau.com.au/forums/topic/89234-power-fc-qs/#findComment-1616770
The extra features on the datalogit eg airflow voltage ramp table etc - could you ask your tuner to give you a copy on a usb drive or something so if you did loose the tune you could go back to them and get them to reload it so you dont have to start from scratch.
Just wondeing if it is like a file you can store..
thanks
https://www.sau.com.au/forums/topic/89234-power-fc-qs/#findComment-1618511
yeah it saves it as a file you can take home on a floppy disk etc.
thanks
https://www.sau.com.au/forums/topic/89234-power-fc-qs/#findComment-1618546
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
