  • 4 weeks later...
  • Replies 80
WTB !! Wanted to buy, R32 sedan.
For drivetrain conversion, so engine/gearbox condition is unimportant.
I'd prefer something registered or registerable, but will consider track only chassis as well.
PM me if you've got something.
FS:
Stock Cefiro drivers seat
Looking for $50 + postage to get this thing out of my garage. Has been sitting around since i got the car and is in perfect condition (with rail).
In melb but can post interstate. Got a quote for ~$70 to SA when someone asked me about it.
:D
sabelt 4 point harness 1994 manufactured... really good nick with sabelt shoulder pads $100 firm suit all cars pretty much
trust oil filter sandwich block with tapped sensor holes $100 firm suit sr/rb/ca
rb20det t3 turbo in very good nick no leak, shaft play is at a very minimal - normal running tolerance $220 firm
a31 hicas pump and lines $100 firm
a31/32 aircon condensor/pump/actuator (some lines included... half are cut so are useless) $80 firm
ssr reverse mesh rims 15x?? with a 0 or neg offset (running 205's with tiny bit of stretch) and 16x?? of the same style running +20 or so offset (id imagine 16x7.5 or 8 +25) full set for 1k very minimal gutter rash if any and no dents - fully balanced - $1000 nego to split into 2 pairs if someone willing to buy the other pair
a31 disc to disc rear end (will bolt into s13/r32/c33) can supply with or without tight viscous lsd - $400 or diff on its own $250 if someone wants to buy cradle for $150
black razo ball shifter - $50 firm
white razo ball shifter - $50 firm
a31 sideskirts (unsure of brand - similar to T's garage or autech - fibergrass) damaged (all in one piece just bashed and needs respray) $100 firm
any queries send pm... will accept near to original price if offer suggested
thanks guys
willing to swap also - looking for 2nd hand good condition z32 afm, ap enginerring rb20det pfc, rb26 crank and rods in good nick, blitz lm or trust air nx pod filter brand new or 2nd hand in very good nick, any ceffy bits mainly a drivers side rear window motor/scissor/mechanism/assembley doohicky
thanks again guys!
  • 3 weeks later...
i have a few items available.
Aftermarket cefiro grill open and meshed - half painted - sold
Perfect condition s1 taillights - $150 neg
JIC 8k springs from Coilovers (just the springs 200mm approx free height and approx 63mm internal diametre- $100 neg
pm me or email me at [email protected]
cheers
resin
Edited by Resin
  • 1 month later...
rar...
A31 drivers side rear door complete with glass - $200 navy blue 1 bit of paint chipped off size of 10c piece
A31 (possible R32) Aircon setup - $120
A31/R32 Powersteering reservoir with lines to pump - $100
RB20DET Injectors x6 pulled from running engine - $160
Greddy 42mm Black boostgauge mechanical - $70
A31 (possible R32) Hicas powersteering pump - $80
A31/S13/R32 Hicas power steering rack - $180
Black Razo 8ball gearknob - $40
Catchcan polished with fittings and oil level reader - $70
A31 RB20DET 4stud hubs/rotors/calipers front and rear - make an offer...
Apexi RSM (oldskool version) - $100
A31 RB20DET Coilpacks in brackets x6 working fine - $100
A31 Late model tailights (tint strip around edges from factory with centre garnish) $230 drivers side has 40mm crack in it... could be fixed with new lense or plastic weld
A31 sideskirts - autech or something... look good - few cracks and poorly painted navy blue - $100 easily repaired
all stuff is in SA... not really willing to send interstate atm - don't have time to
pm's welcome... thanks
  • 4 weeks later...
Hi guys,
For any Cefiro or R32/R33 owners that are interested, we have just posted a new special in the business trader section for our brand new JJR Cooling-Pro Alloy Radiator upgrades.
We are offering them currently for $399 each.
Click the URL below for further details.
http://www.skylinesaustralia.com/forums/in...howtopic=117584
Regards,
Steve
Hi guys,
Regards,
Steve
Cefiro radiator is IDENTICAL to R32 for those who want to know, but it is a good idea to list cefiro as an option cuz most people have no idea :P
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
