I have similar tyre sizes and i run 32psi....
I do have massive camber on the rear wheels so i do tend to let them down a bit 30-29 area to get a little more grip on the road....
Anything more than 32psi and i get wheel spin due to lack of contact...
https://www.sau.com.au/forums/topic/89439-tyre-pressure/#findComment-1614290
Hi guys...how many PSI would u pump into yer tyres on a ECR33 fer sizes from 225-255/40-45/17?
What does the tyre manufcturer recommend?
I'm running 235/45x17 Bridgestone GIIIs at 36psi - because that's what B/S recommends.
https://www.sau.com.au/forums/topic/89439-tyre-pressure/#findComment-1615171
43 psi 225/50/r16 - but check the max pressure rating of the tyres you have - and actually this depends on the tyre. For example the Pirelli PZero Nero optimum recommended pressure by Pirelli upon phoning them is 39 psi for the 225/50/r16. I prefer 43 psi though.
https://www.sau.com.au/forums/topic/89439-tyre-pressure/#findComment-1616147
damm wtf.. 43PSI?
thats high man... hardly any grip. Drop them down to 34PSI or best would probably be 32PSI in dry and like 29-30PSI for rears in the wet.
https://www.sau.com.au/forums/topic/89439-tyre-pressure/#findComment-1616886
For most tyres people recommend 32psi.. 43psi is ALOT.. wonder why they recommend it, i'm sure there is a reason..
Yeah.. on average i've heard about 32 - 35 is a good balance on tyre wear + grip.. if you run them to high they don't wear evenly accross the tyre I believe..
https://www.sau.com.au/forums/topic/89439-tyre-pressure/#findComment-1617027
You'd need a very good reason to run >40psi. The max psi rating on the sidewall is not an indication of the pressures you should run.
I would try with 34psi all round and tweak it from there based on your personal preference. I run 35 on the front, 36 on the rear (235 F, 255 R)
https://www.sau.com.au/forums/topic/89439-tyre-pressure/#findComment-1617518
It was 39psi recommended for those wheels by Pirelli.
And I recall that the reason I put the pressure up was because the outside of the wheels was scrubbing really bad at high speed cornering with 34 psi. 39psi is ideal for normal driving. The reason I used 43psi was that during high speed cornering it stopped my tyres outside edge wearing out too much. The inside wore due to the negative camber. At the end of the day the 43psi puts a bit of extra pressure on the middle, so it wears a touch faster in the middle, and causes it to be 2mm further worn by the time it reaches the wires at the bottom of the tread.
That pressure was ideal to me. -1.2 camber was my setting for the above.
Just bought new 18"/9.5" and 18"/8.5" wheels and was recommended 40psi. Havn't confirmed recommended pressure with anyone yet though.
Front rims 18"/8.5" with Bridgestone Potenza RE-01 235/40/ZR18
Rear rims 18"/9.5" Yokahama ASpec dB 265/35/ZR18
lowered now and have -2.84 camber on the rear and have not rolled the guards.
https://www.sau.com.au/forums/topic/89439-tyre-pressure/#findComment-1631119
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
