Hi, as the title states: does anyone know if the 25GT manual gearbox is the same one they use in GTTs?
the reason i ask that is because im planning to turbo my rb25de neo but need to find out if i have to upgrade the gearbox or just the clutch?
cheers
Edited by saga
rebuild the RB25DE into an RB30DET....great engine with a ton of power.
Change the transmission...it will die with that sort of power going through it, upgrade toa  GT-T box.
thanks Dan
so you are saying that the 25gt manual gearbox is different to the gtts one?
have you changed the standard gearbox in your 25gt for the kind of power you are making(150rwkw correct?)?
cheers
Edited by saga
thanks Dan
cheers
Yeah the gearboxes are different, very similar but different. I left the auto in my R34...it only had a couple of clutch plates less than the GTT box, and also had a lower stall point so wasn't as excessively abusive on the mechanicals...a manual box would cop it a lot more, so should be swapped.
I don't have that car anymore, it was stolen and written off...so I'm now going through the upgrade process with my new GTT.
Once you've driven a high-compression car with a turbo, it's funny going to the factory lagmonster!
haha thats right! i like the idea of high compression engine with a turbo less lag!
if i leave the factory 10.1 compression and run a turbo with no more than 7psi boost, instead of using a factory gtt turbo, in theory wouldnt i make more power with a bigger bolt on turbo like an gt2835?
im also think an aftermarket high mount manifold, an aftermarket front mount intercooler and a gtt upgrade full exhaust. many of these parts are selling at a bargain price on ebay. hows this package sound to you?
oh and ofcourse PFC!
The only other example of a high-comp R34 turbo conversion was in Greece, it used a TO4E, which spooled up very well with the compression. Best to wait and see what turbo you decide to buy...as you're going to have to get custom piping and flanges for the exhaust and intercooler, nothing on e-bay will really suit.
Don't forget to try and get hold of some GTT injectors, a fuel pump, and an uprated fuel regulator to make tuning more simple.
Here is the other 25GT
thanks for that,
so heres the plan:
aftermarket high mount manifold designed for rb25det with t3 flange and external wastegate type(i suppose it should be a direct bolt on to rb25de neo right?)
hks gt2835 turbo (as i can buy one off my mate dirty cheap)
external wastegate- just love the sound
and all other gtt parts as you mentioned above.
now just two questions: which type of PFC to get? and what about the stock airbox? would it be sufficient? or need custom intakes too?
cheers
OK...both of these cars used the e-manage, but I'm 99.9% sure you'll be fine using the normal GTT PFC, as all the connections and ECU sockets are the same. The only thing I think you'll neeed to invest in is the optional pressure sensor for the PFC. The GTT has one connected from factory, this will most likely be the input that would confuse it, if it wasn't there.
Stock airbow should be fine, put a pod in if you feel the need.
Can you get me one of these dirt cheap turbo's? :D
Can you get me one of these dirt cheap turbo's? :)
well not exactly dirty cheap, its a garret turbo dont know the specs yet but similar to a GT35, for under 2k. cheap in comparison to an internal wastegated hks gt3037 which retails like 5k if im not wrong.
so yeah sure mate, if u want one i guess i could get u one. no worries
Can you get me one of these dirt cheap turbo's? :(
you would probably need custom pod intake to make room for the highmount
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
