RB24 is made by using RB26 crank and rods yeah?
yeah gtr rods crank and 81 mm pistons either toyota factory semi forged or tomei stroker kit bore out the 20block and also a custom head gasket or tomei head gasket
https://www.sau.com.au/forums/topic/89626-hpis-r32/#findComment-1616855
Must be pritty cheap then, Also anybody done this and how hard was it?
I have all the parts necessary to build an RB24 and I have had them for about 5 years;
GTR crank
GTR rods
ARP rod bolts
ARP main bearing studs
ARP head studs
4AGZE pistons (high pressure cast with ceramic coating)
Total Seal Piston rings
ACL race series bearings
Cometic cylinder head gasket
and a 180,000 ks RB20
All I need to build the engine itself is a Nissan RB20 gasket & seal kit, a set of cams, pulleys, valves, valve springs, solid follower conversion and some machining, inc porting the cylinder head.
But I haven't done it, in that time I have done 2 X RB30's for my own use. An RB30DET using an RB25DE top end and the latest RB31DET with an RB26 top end.
WHY?
Because the RB30 is cheaper to build, cheaper to maintain and much easier/cheaper to get parts for. I can make more power/torque with the RB30 without reving it any more than a standard RB26, so I don't need expensive top end parts, high rpm water & oil pumps, low rpm puilleys for the alternator, power steering pump, shorter diff/gearbox ratios, inlet plenum etc etc. Plus I can do it at lower boost, because the RB26 top end flows so much better. Less restriction at lower boost and higher airflow = more power at lower stress.
It's not the cost of the crank, rods and pistons, they are relatively cheap. It's all the other (costly) things that I need to buy for an RB20 to make the RB24 conversion worthwhile. Stuff that I simply don't have to buy when I build an RB31DET.
I will build the RB24 one day, but just for interest sake, not because it's a good idea.
:D cheers ;)
Edited by Sydneykid
https://www.sau.com.au/forums/topic/89626-hpis-r32/#findComment-1617065
4agze 81mm doesnt exactly give u the full monty RB24 .. its more RB23 .... 82mm Tomei .... must be gold plated inside for the price.. .... pistons....will get u a more truer rb24..... but for the price... 800cc or so more for 1900bucks .. or 680 for 2sets of 4 toyota pistons from factory new. (340 a set) .. isnt worth stressin about. machine costs are the bigger issue .. and head work to suit the combustion chambers to suit the new bore.
i got over going rb24.... going Rb25.... cheaper.
Matt
https://www.sau.com.au/forums/topic/89626-hpis-r32/#findComment-1617079
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
