IF YOU POST WHORES
Hijacked the thred
Write crap on thred or writing shit visa versa
Wasting the space with crap/off topic replys
I'll farking move every sigle reply to the west waste land! if I have to!
I am not happy how all the threds are all over the places, especially you are trying to ask about engines but some people ask another person how their day was! WTF?? stay on topic!:uh-huh:
KEEP THE TOPIC IN MIND WHEN YOU FARKIN REPLY ON ONE! ok? FFS!
PISS ME OFF SOO MUCH!:bahaha:
see ya :burnout:
cheers
Joe
https://www.sau.com.au/forums/topic/8989-shit-hit-the-fan/
