I had the same problem.
Switched to Redline Superlight weight shock proof!!
It's now a dream to drive, whether its a cold start or up to temp. it's faultless.
It's expensive at about $135gal. (you would use just under a US gallon for a Skyline Gearbox)
I strongly recommend it if you want results :)
https://www.sau.com.au/forums/topic/90100-redline-or-motul/#findComment-1625454
My car is crunching gears,  :O  (recently serviced). I doubt it's the synchro's as the car has only done 85,000 and I don't drive it like crazy.
Which gearbox oil is better, redline or motul with graphite in it?  :D
If you can get some Kendall synthetic gear oil you will be very suprised how much better your gear change is. Also I slipped some Slick 50 in as well.
https://www.sau.com.au/forums/topic/90100-redline-or-motul/#findComment-1629238
Firstly, I believe there are 3 oils in the Shockproof Gear Oil range. Superlightweight, Lightweight and Heavyweight.
From what I understand, if your car use is "normal" and your box is in good condition, you should use the Superlight Weight.
For older g/box's and/or for more abusive use ( track use etc. ) go the Lightweight.
Then the Heavyweight is for dog box's etc and extreme power / usage.
But even after saying that, I'll be using the Lightweight Shockproof in my fully overhauled g/box only because I've used it before and know how well it works.
Hope that helps some :(
https://www.sau.com.au/forums/topic/90100-redline-or-motul/#findComment-1638070
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
