Hello all, i was just wondering if there would be enough people in Victoria with 4 doors that would be interested in meeting up for a cruise or just a meet up. i wouldnt mind meeting some other fellow 4 door owners. Hopefully the cima should be regoed within the next 2 weeks and then it will be cruises gallore. So if i could get a rough estimate on the amount of people that would be interested in a get together just so as we can decide wether or not it would really be worth it.
and say wether you would like a cruise or just a meet up somewhere.
Cheers Benny
https://www.sau.com.au/forums/topic/90183-4-door-cruise/
  • Replies 56
ok i was thinking of making this meet the weekend after autosalon weekend. so making it the 20th of november?
what does everyone think about this? gives us abit of time to get the shout out to other 4 door owners
yerp yerp sounds ok to me :(
https://www.sau.com.au/forums/topic/90183-4-door-cruise/#findComment-1642007
got to drive Sarumatix's R32 4 door beast in and out of Driftline day before yesterday while we shuffled cars around... oh how jealous I am of your car. And once we were done with that we chopped off the roof of a 180sx for a Ute conversion :D
In other news I just bought an R32 GTS4 (2 door though). Hopefully I'll have the RB25DET swap completed soon before it leaves japan for Australia.
https://www.sau.com.au/forums/topic/90183-4-door-cruise/#findComment-1672382
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
