hey guys i been gathering all my bits together for my rb26 engine build after a recent piston ringland cracking :O
these bits ive got so far:
INTERNALS:
JUN 2.7L stroker kit
JUN forged crank
JUN forged connecting rods
JUN cosworth forged pistons
JUN oil pump
JUN head stud kit
JUN big end stud kit
JUN 272 degree/11.35mm lift cams
JUN adjustable cam gears
JUN titanium retainers
JUN heavy duty valve springs
Nismo bearings
HKS metal gasket kit
valve guides
Gates timing belt
n1 waterpump
INTAKE:
HKS T04Z (0.81) turbo
Huge K&N Pod filter
Trust stainless steel exhuast manifold
custom 3" aluminium intercooler piping
HKS 50mm external wastegate
EXHAUST:
4" dump pipe into 4" exhaust, to 3.5" after cat
4" magic cat converter
3.5" stainless steel mufflers x 2
FUEL SYSTEM:
sard 1000cc injectors
sard dual entry fuel rail
sard adjustable fuel pressure regulator
bosch 044 fuel pumps x 2
goss intank pumps x 2
Alloy surge tank
twin fuel lines from pumps to engine
DRIVELINE:
custom twin plate clutch
gtr 5 speed gearbox
GTR rear diff and axles
4.3 diff ratios
OTHER ENGINE BITS:
Autronics SMC ecu
Autronics CDI ignition amplifier
MSD coilpacks
nismo engine mounts
nismo gearbox mount
custom 9L baffled sump
gotta get a 100mm+ intercooler trust or hks etc, and a oil cooler kit.
anything ive missed?
and whats the max power i could get from the package with the 0.81 housing HKS T04Z turbo?
i realise the gearbox is gonna last 2 min :)
cheers
Brad
https://www.sau.com.au/forums/topic/90438-what-power-will-this-combo-make/
post-7531-1128849632.jpgsounds like a great combo i used..
tomei 270 cams
head port and polished
ferara double valve springs
ferara 2mm oversiae valves
custom titanium lifters
oversize sleeves
ferera valve locks
cp pistons
cp oversize rings
bore and hone block
extra oil injectors for block
billet wiesco con rods
nitrated crankshaft
meo pins
bushing crankshaft ( this means taking the welsh like plugs out of the crank and block and putting in thraded allen key bolts )
n1 oil pump
n1 water pump
tomei head gasket
race bearings rear and main with extra oil holes drilled in bearings...
greddy adjustable cam gears.
greddy fuel rail
1000cc injectors
their was a few other bitz and pieces... cant remember
but anyway i got 500 at the rear for its first tune after the 2000km run in but i only have 1 td0625g so i am in the process of adding another ,i am also putting in a trust 6 speed dog box this week should help things .
ps.... what blow off valve r u using on this engine....
thanks
my boss had his 2.7 stroker time attack style 33 gts-t arrive from Japan this week it's fitted with a Apexi RX6 and it made 306rwkw on 1.4 bar (pulp) it will make an extra 100 rwkw or so with race fuel and a more aggressive tune so I'd say yours should easily reach this figure to. Its ruined my car for me though when he let me drive it.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
