At the risk of firing this thread off on a tangent - does the R32 V-spec have an active diff? I always assumed it had, but in the absense of hydraulic lines I now doubt it somewhat.
From memory it has an ATTESSA System with a higher sample rate (100 times per second rather than four), but does this really make such a huge difference?
Reason for asking is given in the attachment - wheelspin. The graph shows a data log from a nothingburger lap of Wanneroo. Particularly through Shell (left hander approx 216 secs into the log) the jagged blue line (rpm) indicates wheelspin - and lots of it. Not sure which end is causing the problem - my first move was to have a go at the suspension rather than the diffs. But the question stands - do R32 V-spec suffer from this nonsense?
what you need is an ATTESA controller, the 32s were very rear biased :D The controllers make a huge difference to how early you can get on the gas without too much oversteer or wheelspin
Never seen an R32GTR V Spec with an active diff, only ever seen them on R33's.
What Duncan said is spot on, ATTESA controller required.
Plus it may pay to check the ATTESA clutch pack, as the power goes up they tend to slip and not deliver enough front torque.
:O cheers :)
:O cheers :)
The wheelspin feels much more like the inside rear spinning rather than a front/rear torque distribution - hence the fix is (broadly) more so to reduce the roll couple (Lower ride height), increase the roll stiffness (sorted) and to tighten up the rear diff. The wheel is sufficiently lightly loaded through Shell to not have much affect on the handling balance when it loses grip - it just annoys me because you cant let the thing drift out against the ripple stip on the exit of Shell during the run up to Kolb.
What you are saying about the ATTESSA pack is correct, however presently I have a surfeit of grip over engine output. Hence the car is still understeering - although this is halfway to being fixed also. Just time & money really, like everything.
Well you can certainly re-shim the rear diff as well if you are confident it is the inside wheel spinning. What system is the data logging from? Can you add wheel speed sensor input from both rear half shafts?
But until all 4 wheels are spinning under power out of corners you are not taking full advantage of the system :(
Yeah, tightening up the diff sounds like the other best option.
I used the highly technical data logging method of getting a mate to stand on the inside of the corner to see what was happening. Unfortunately there are not any more inputs available for the data logger. (Although I would love to better get at most of what is available in the Skyline eg TPS, steering input, ATTESSA outputs etc etc.)
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
