hey all i decided today i would give gtr its first launch sence ive had and well all i got was 1st,2nd gear fishing all the way up the road...didnt feel like there was any front wheel drive at all....just left 2 big black marks for 30m or so.
my question is should my gtr with only cat back zorst,hks pods and 0.9bar dom this or should it grip like all f.u.c.k and sit me back?
also have 255 michlin tyres all round with dam good tread left on them....any help would be good?
also checked fuses and there all fine
https://www.sau.com.au/forums/topic/90592-1st-launch-in-gtr/
i also read an article in the new hpi that says the attesa system can get air in it and can cause the system to work incorrect or real slow....but it said this happens from clutch and gboxes being pulled out and stuff?mine has standard clutch but u wouldnt no whats been in there
How far does your torque gauge move? from what your saying it should be going nearly all the way to the 50.
Doesn't sound normal, i barely get any wheel spin, just grips and goes.
As already suggested, try bleeding your ATTESA. very simple/cheap to do. But it could be a worn out transfer case, they have clutch packs in them, if its had a lot of ks and lots of thrashing then they could be worn? Don't think you can really test it. Besides getting ti pulled out and looked at.
Ohh make sure you have a front driveshaft it could of been taken out and never put back. Also worth checking to make sure you don't have an ATTESA controller somewhere that is turned 100% to rear.
thanks alot ferni ill check all of the above...torque gauge moves ok but in the hpi it said it should move with power and precise movements,ill bleed the system and see what happens....if i cant get and nissan fluid they say to use what else will to attesa system
How many mates in the trade do you have? I would do a quick check with a diagnostic tool and see if it brings up any errors.
A diagnostic tool will do a simple check as it may be a faulty sensor, and there are quite a few that make up the attessa system. Im not to sure what a rebuild is worth but check the simple stuff first.
Cheers
Sumo
Just do it exactly how HPI says. I have read it and it is exactly how the manual describes.
Don't just use ATF. Nissan requires a specific type of ATF.
The next step if the bleed does not work is to check sensors....the bleed is by far the easiest way first.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
