Can u guys help me out on this one because ive got no idea. Ive got a sky and need some help on the fluids that are recommended for it.
I know that engine oil should be changed every 5000kms with good full synthetic oil as well as have the oil filter changed.
What about
- transmission oil
- radiator coolant
- power steering fluid
- brake fluid
Can u use any type of fluid or do u have to use special ones that are specifically designed for high performance cars???
Some recommendations on the fluids u guys are using for your Lines would be appreciated
thanks
https://www.sau.com.au/forums/topic/9101-engine-fluids/
I use Silkolene DOT4 for my brakes. Its damn good compared to the crappy Mobil and Castrol that regular auto shops stock.
Good sources for quality fluids, both transmission and brake, is motorbike shops. They stock really good brands like Motul, Belray and Silkolene. One type of racing brake fluid Silkolene make retails for about $38 for 500ml's! I use the cheaper $16 dollar one which is good enough for most people id say.
Generally i change brake fluid once a year, but I dont do alot of motorsport, so it tends to get changed when I can feel the pedal is horrible. :D
I use Mobil 1 10W/30 in my Skyline for engine oil.
Red17
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-136994
So engine oil doesnt really matter which ones u use just as long as they are full synthetic rite?
thanks for the brake fluid tips i think ill hope down to my local bike shop and pick up a bottle of that stuff.
With transmission oil and brake fluid do u have to flush it or can u just top it up???
Sorry to be a hassle but one more thing guys...do you have to flush the radiator coolant or can u just top it up with Nissan's radiator coolant when it gets low
Thanks again
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-137497
You can just top it up I'd say...but every now and then (maybe once a year) do a full flush, because often stuff can just sit at the bottom of the radiator. Once i thought my radiator was clean (and the water was), and heaps and heaps of crap came out of it.
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-137553
Skyline_Paul: I just changed the oil in my gearbox and they feel as smooth as silk. I used Caltex Gearlube 70w-90 coz thats what they recommend for the car and its well worth it (used about 3.5 litres)... no more nasty clunking. For the engine I used 5w-40 Full synth (nearly used 5 litres). For the gearbox all you need is a 1/2 inch rachet (the square bit opens the bung) and the motor you need a 14mm ring spanner or rachet depending on what you perfer.
Filter for motor No. 145a
Petrol Filter Z200
Cheers
Sumo
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-147598
Hey Sumo thanks for the help i havent yet changed anything on my car yet...since i just got it the other week
just wondering how long should u leave it until u have another gearbox oil change? (kms??)
and also are u from the west cause i need some help...i am crap when it comes to car engine maintenance
cheers
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-150214
Im in Country NSW. Near Tamworth.
If you had all the filters and oils would only take half a day to do max.
Changing the oil in my Diff today, EP 85w-90 was recommended for the R32 GTR, but it reads its not recommended for LSD's? Im not sure whether the R33 is a LSD or not?.
Sumo
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-152089
Oil Filter = Z145a
Fuel Filter = Z201
Air Filter = A360
If you have and Auto you are best to change the Trans Fluid and filter every 50,000k's. If you have and LSD, which all Turbo Skylines have you should change its fluid with the trans flud. An lsd is almost useless if the Fluid is maintained. Manual Trans Fluid should really be changed at 50,000 to 60,000k's also just to b safe, especially if you drive it hard. Coolant Should be changed every 2 to 3 years and Brake Fluid every 2 years. Power steering fluid really should last you 100,000k's.
Im fairly sure the pads on all skylines are:
Front = DB1170
Rear = DB1220
Discs; (Not 100% sure if these are right for r32 GTST)
Front = DBA4963
Rear = DBA908
I use NGK BCPR6EVX Plugs in my R33, but if you drive hard you should use a 7 heat range. BCPR7EVX
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-169010
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
