sorry there late... havent been online for a while
here are some pics of the cesracing twin dump i fitted to my R33
Dave
Edited by r33freely
angled below horizontal??
surley the sensor dosent know if its upside down or not?... could you please explain to me how it is that they dont work like that?
Dave
Edited by r33freely
Actually, the 02 sensor obtains condensation during initial start up,cold start, and if operated at an angle below horizontal then the sensor can fail quite quickly...
This is pretty common knowledge...the heater element also is liable to fail...
  • 3 weeks later...
The exhaust system does not give your engine it's backpressure.
The turbo does. By changing the exhaust system you allow the turbo to extract gasses more freely which means that turbo response INCREASES. Boost will come on sharper and you will be less likely to spike or overboost.
The smaller the exhaust system, the less boost you are able to run.
I know the above to be fact, however, I will say this:
I don't personally have dyno proof of when the power change is in a 3 inch system but I can assure you that it definately won't make it laggier. It will only remain the same or increase response.
Sorry, mate. I know this is a bit late since your post, but your opening statements are basically wrong, although right in some respects. The whole of the exhaust system from the exhaust valves to the exhaust tip contribute to "backpressure". This is simply the resistance to flow that the exhaust gases experience before they exit at the exhaust tip, in other words the pressure drop through the system. This means that there is a base pressure that has to be made in the cylinder to enable flow to occur. That pressure is effectively the "backpressure". Naturally, the reciprocating motor overcomes this backpressure and then some.
The greatest contributor to the overall pressure drop is more than likely to be the exhaust wheel in the turbo, but every bit of pipe, every bend and every restriction plus the valve and ports in the cylinder head contribute to that pressure drop.
To say that the turbo "extracts" the gases is just plain wrong. The turbo would only extract gases if it was driven by something else. But the exhaust gases drive the turbo. Reducing the pressure drop downstream of the turbo exhaust wheel enables a higher gas flowrate and increases the relative pressure drop across the exhaust wheel, thus increasing the driving force to the exhaust wheel.
Your conclusion about responsiveness, etc., is correct - but you got there by the wrong route.
Or do you understand all this and you just didn't express it very well? Sorry to go on, but there are a lot of incorrect ideas mixed up with fact in explaining how a turbo works on the forums. We need to get it right. So if anyone can add to what I have said, I would welcome their input.
Cheers.
Thats spot on... I like to think of it being similiar to airflow through a radiator.
High pressure one side, low pressure in the engine bay will see good airflow through the radiator.
Higher the pressure in the engine bay the less airflow through the radiator.
Which I think is 'similiar' to what happens inside a turbo, lots of back pressure inside the scroll trying to escape out past the turbine wheel, place a low pressure area after the turbo's turbine wheel and you will most definitely have improved flow over having both sides with high pressure. :O
The gas will move faster as a result spool/response/power will improve.
Edited by Cubes
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
