Parts I have left are now listed on the link below. someone bumped this old link but most of this stuff was long gone
Parts List
PH Nao 0431 895 772 or PM. Thanks
Edited by XJ40
R32 GTR Carbonfibre bonnet with pins $650.00 (Will Part Trade Alumium Bonnet)
Black Rays Nismo R32 GTR 17x9 inch forged monoblock alloys $1250.00
Brembo R33 V Spec? GTR Rear Disks, and calipers. Excellent Condition. Fitted to R32 GTR $Offers
pics of these to [email protected] pls
  • 3 weeks later...
Hi...where in southside are u? Can i come by and take a look at the bride bucket seat? And will the rails fit into a r33 gts-t? If they dont, anyone wants the rails if i take the seat? :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
