Item: R32 RB20DET, ex GTS4
Item Condition: Good. Has had 100k timing belt and water pump replacement within last 10k km
Reason for Selling: Upgraded to RB25DET
Price and Payment Conditions:$600, freight outside Melbourne at buyer's expense, payment method negotiable
Extra Info:Engine is missing: Turbo, coil packs, differential
Contact Details:post or PM
https://www.sau.com.au/forums/topic/91312-rb20det-r32-gts4/
I'm really not sure - it was a replacement for the original engine after it shat a piston. It's probably around the 100k mark. It's had the timing belt and water pump replaced quite recently.
https://www.sau.com.au/forums/topic/91312-rb20det-r32-gts4/#findComment-1655499
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
