I've picked up a Nismo FPR, in an attempt to squeeze another 10% or so out of my rb20 injectors, and hopefully pull around 200-210rwkw with my highflow.
Just wondering if there is anyway to adjust it .. without having a proper fuel pressure gauge?? I thought there might have been some markings on there, but doesn't appear to be anything like that unfortunately :D
If not, I guess I will leave it to the tuner to do. Its a 5 minute job.. I am just worried I could get charged $50 for labour to fit it!
https://www.sau.com.au/forums/topic/91376-adjusting-nismo-fpr/
I got one of these fitted to my car 2 months ago, and was charged something close to fiddy bucks for labor (good thing I had some other things fitted at the same time!) I thought it was something best left for a tuner to do. As far as I could tell, to adjust it you need to turn the nut on the end? No way you could safely do it with out some sort of gauge though.
"My cat's breath smells like cat food."
So if I bought a FPR with a gauge on it... adjustment would be a piece of cake? Provided you knew what you were doing of course...
What's the difference between a normal FPR and a Rising Rate FPR? What is the optimal setting of this thing?
if you are going for more power than the stock injectors require my advice is to just get bigger injectors. the problem with upping the fuel pressure is that you can cause problems with the spray pattern and in extreme cases cause the injectors to leak. another very common one is that with the extra pressure you can find some leaks will surface in your fuel system.
for example say stock pressure is 38psi with only atmospheric pressure. and stock boost is 7psi that's 45 psi total
now you want to run 4 psi more more pressure. this is 42 psi. and of course with the new turbo you are running 18psi. you now have 60psi at full boost. the difference between 45psi and 60psi is 15psi... that is a lot and i would think is more than the stock system is designed to handle.
OK Mr Beer Baron - thanks for you help.
I'm hoping to chase at least 250rwkw and if possible, 300... perhaps you could PM me a list of parts that would get me to that mark? Also, tell me what the best turbo would be for my application :)
well i'm by far an expert on anything (especially RB25s!) but if i were doing it i'd have (for 300rwkw):
600cc injectors
Power FC
some form of boost controller (personaly, greddy profec B II)
FMIC
upgraded panel filter, or pod
larger exhaust from turbo to tip (3inch should do it)
Oil cooler
decent clutch
as for turbo i'm not to sure what the gun combo is on an RB25 but i think an HKS 2835 kit could be pretty close to the money.
Now just to keep this on topic. Predator, you'll need two things to adjust the reg.
1. workshop manual (to find out what pressure it should run as stock base pressure)
2. Fuel pressure gauge.
other than that a 10mm spanner is the only too required to set it. but just heed my warning about upping base pressure, and upping boost.
Thanks BB, since I drive an Auto does this mean I can scrap the clutch and the power fc?
Could you take a look at my site and tell me what else is needed? I really appreciate your help :(
Now I'm going to stop invading predator's topic :(
Think I'll leave it to the tuner if there is no easy way.. to buy a gauge will cost more than $50 for them to fit and fiddle with it :(
in my case, the rb20 is coming out in about 3 months, so no point stuffing with injectors or aftermarket ECU.. I just want to try and crack a low 13 on the cheap before the engine comes out..
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
