as the aftermerket crank swinging at a bigger angle to create the displacement
so those kit add EXTRA stress to the bearing
Extra stress on the bearings?? we are talking going from 2.6 to 2.8 here, and some of that capacity is gained from the overbore! And you are dealing with a crank that is MORE balanced than the stocker, so id say without the nasty harmonics or vibrations that ive heard people talk about, wouldnt there be less stress on the bearings than a stock rb26 crank (at the same rpm)?
as sydneykid has explained, the square 3litres "have superior rod/stroke ratio (1.79) to RB26s' (1.65), this means less side loading on the rods and the crank."
BUT, as i originally posted i dont want another 3litre thread so lets talk no more of it, i want Jap stroker crank experiences here :)
ok back to topic the three HKS kits as i understand them are
stage 1 (600ps rating)
crank
rods
pistons
$6819.12(deliveried)
stage 2 (800ps)
crank
rods
pistons (but the pistons are coated)
$8,720.87 (deliveried)
stage 3 (1200ps)
crank
rods (22mm judgen pin)
pistons (but the pistons are coated)(22mm judgen pin)
$10,738.65 (deliveried)
in my opinion i think stage 1 is good valve for money full forged stoker kit internals for under $7000 deliveried and i believe it to be capable of much higher hp then rated, coating pistons does make that much of a difference (600 to 800ps) and if i had known earlier about this kit well my current build might have been alot different. I could only see someone going above stage 1 (straight to 3) if you were out to break some hp(dyno) or drag records.
my 2 c
ps HKS conrods are simple awesome
thanks for the RELEVANT post pnblight!
I was just about to go for the stage 2 kit, then remembered that customs will make me pay 25% on top of that cost (10%gst + 15% duty)! Might it slip through?? most probably not, as apparently they are shipped in a reasonably sized wooden crate, and the declaration from nengun (or whoever) will state the value of the parts..
Now youve got me thinking about the step 1 kit. In true Jap fashion it is likely to be underrated. If a combination of stock crank, average quality upgrade rods and pistons can support 600PS, then surely the HKS 'baby' kit can handle 700+ps. I would think they would quote for an extremely long reliable service life supporting 600ps, perhaps circuit car reliable, in which case under street conditions should easy support more. Any thoughts on this??
from there other kits you can say the crankin stage 1 is good for 1200ps the rods in stage 1 good for 800ps as both components are the same the only factor down rating the kit is the piston coating ,I think a quatity forged piston from HKS would be capable of alot higher ps rating i think the reason for the rating is more to given a justification for the price differences between the kits as who would pay the exact money if the rating were more like
stage 1 900ps
stage 2 1000ps
stage 3 1200ps (for example only)
do you see what i mean
sly33 would it be possible to maybe try buying it for america instead as the free trade agreement (might be cheaper just an idea)
pete
if your paying 10K for parts i reckon it's worth hopping on a plane over there and picking it up yourself. sure it costs $2K but you will save money on frieght (maybe $400?) plus can possibly negotiate a cheaper price (save maybe $500-$1000) and save duties ($1400). you would have to take the crank as carry on (carefully packed in a bag) and put the rods/pistons in your check in. could be a bit ambitous you say but on my last trip to japan i carried over 50kg back. more than 30 of that carry on.
i got funny looks carrying on some springs flying domestic, imagine the looks when they run a fat crank through the scanner! haha
Main problem with that idea for me is that i wouldnt have the time to go over there! But youve got me thinking.. i know guy whos just moved there.
Edited by SLY33
pete, i see what you mean.
but surely there are other diff's than just some piston coating to justify the extra $$? i heard or read somewhere that step1 and 2 cranks are forged counter, whereas step 3 is full billet crank like the JUN one previously mentioned??
not exactly sure..
Edited by SLY33
To quote Tomei on their 2.8 counter weight crank:
"Only 200cc displacement up. It causes dramatic change to RB26. Change is super response and big torque."
As i mentioned earlier, the 200cc extra must make more of a difference than most people would think.
I think you will find (and I may be wrong), that the HKS step 1 kit does not come with conrods, the kit uses 121.5mm rods, so you use your old ones.
Also, all 3 cranks (step 1, 2 and 3) are different, but I believe they are all 12 counter types.
The Tomei RB28 kit includes Arrow rods but uses an 8 counter crank (from the Z tune)
hi mik, ive found that depending on who supplys the kit, most kits come with rods. The only place i found that sold the kit with no rods is Xspeed in Perth.
so is a 12 counter better than an 8 counter? I dont know a whole lot about cranks and only since investigating these kits was the first time id ever heard of a full counterweight crank.
according to the HKS website the step 2 kit is just crank, pistons and rings and is 498 000 yen retail (tax exclusive for use outside japan). the step 3 kit is crank, rods and pistons and rings and is 950 000 yen retail.
it gets frustrating when once source of reliable information says one thing, and another reliable source says another!
heres what nengun offers from HKS, all with rods
HKS 2.8L Kit Step 1 Rated 441kW(600ps)
Compression ratio (Gasket Size)
* 8.70 (t=1.2mm)
* 8.4 (t=1.6mm)
* 8.1 (t=2.0mm)
Parts Included
- Forged piston kit
- Fully forged & balanced counter crankshaft.
-H cross section connecting rods.
* To cylinder block and baffle plate et cetera
Escaping processing becomes necessary.
HKS 2.8L Kit Step 2 Rated 588kW(800ps)
* 8.70 (t=1.2mm)
* 8.4 (t=1.6mm)
* 8.1 (t=2.0mm)
- Forged piston kit (nickel plated & piston surface has a final molybdenum coating).
HKS 2.8L Kit Step 3 Rated 882kW(1200ps)
* 8.70 (t=1.2mm)
* 8.4 (t=1.6mm)
* 8.1 (t=2.0mm)
- H cross section connecting rods.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
