OK, I've recently decided that although i'm totally happy with my R33 and have absolutely no need for a second car (let alone a petrol guzzling 2 tonne V8 boat), I want a Toyota Celsior.
After searching through a heap of sub par VIP jap Celsiors and stocker local LS400's, I've found this Celsior in Melbourne which is pretty much exactly what I had in mind and looks to be the cleanest inside and out I've seen. Will be going to take a look at it on Sunday.
My question is, does anyone have any advice as to what to look out for with these cars? Also what is it worth in your opinion?
I've read through a heap of info and apparently the 1uz V8 is pretty indestructible, but the factory air suspension and front ball joints are possible weak points (damn expensive too). Leather is in awesome condition, only minor wear on the drivers seat bolster.
Any help is much appreciated.
Cheers!
https://www.sau.com.au/forums/topic/91593-thinking-about-buying-this-celsior/
are they the 20b rotary coupe things? don't see many of them around.
not real big on the styling, and the toyota v8 sounds awesome. i looked at q45 infiniti's too but you get so much with the celsior, and they look better.
Yeah 20b rotary coupe.
Where abouts in Melb are u?
Have u checked out some of the importers that specialise in 15yo imports, they have HEAPS of Celsiors, Cosmos etc.
always wanted a nice pimpy VIP celsior...
dunno if id pay 16k for that one... actually i know i wouldnt.
but seeing as theyre not importable anymore then i spose theres not much choice.
ask Shan if he knows anyone with one for sale for under 16k.
yeah was basically going in to it looking at a figure more around the 12k mark if it was in great condition. it's not that far from stock other than the mild kit and susp controller.
every single celsior i've seen for sale since the end of the 15 year rule (and probably during) has been massively overpriced seeing as though the majority were brought in for well under 10k.
but as i said, should probably make a judgement after seeing it's condition in the flesh and what will need to be fixed.
Most of the guys at j-spec (other than me) own a celsior as their daily's. A car like the one you posted will cost you maybe 10,000 to 12,000 on the road. For 16k you'll get like one with plastic wrappers still on the seats. We still get the odd one or two from our suppliers with the papers and everything so it can be imported. The only time the prices are inflated is after the car lands in the country, so its still dirt cheap to get one from Japan.
Danny (Autotrust on the forums) landed a Celsior from japan, and its sooo clean its unbelievable. Like the leather's still plush and hardly sat in. Its a C Type F Package, which is the model that comes with the massage seats for the passengers, seat warmers all around, cassete player for the rear passengers, and electric everything you can imagine.
The one in your pic is like a lesser model (ie its not the shizzle you wanna be seen in by your nizzles)
thanks funky. maybe i should just try and find a nice maxima with hydraulics instead :)
wasn't sure if this one was an f-package or not, so thanks for clearing that up (another couple of bucks off the price)
from what i remember i think the guy who own's that car is the engieener of karizma in abbotsford. cause i seen the guy roll up in that car when he had 2 fix seatbelts in my mates car.
yeah pretty sure he is involved in importing somehow, so you're probably right.
yeah u want something like Craigs lol
THATS pimpin ;)
lol, yeah pretty crazy that thing. had a quick chat at the show and shine
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
