Hey all,
Just got the GTR back from its 100,000km service. All went well except a few things need doing. I had so called K&N pod filters already on the car but the guys who serviced the car said they were not, but infact a K&N copy that cannot be cleaned or something. Anyways, what kind of pod filter should I fit to the GTR? Is it worth spending the extra money on a Japanese brand like HKS or apexi?
I went for a ride in a mates car and he has a HKS pod, and when changing gears it flutters. I WANT THIS SOUND. hehe :rolleyes:
thanks
https://www.sau.com.au/forums/topic/9173-which-pod-air-filter/
Boosted_RB26,
Most of the filters that come with the foam type arrangement are shit, the particles end up working there way through the foam and hitting the turbo, this leaves the turbine with pits in it, which can lead to failure.
I have a Blitz SUS filter, they are excellent for airflow but they allow small dust particles in, so in dusty environments are not very good.
The best and cheapest option is to get a redine filter for $25, they give good filtration with no noticable power loss.
See'ya:burnout:
If you are into "name brands" then I read the Apexi power intake has a good filtration and good air flow combination compared to the other brands e.g. HKS, Blitz, K&N. Also, it is a dry type, meaning you don't need to re-oil it after cleaning (Autospeed).
Otherwise, just go for a cheap Hurricane air filter from Works. Does the job and for ard the same price as the redline filter you won't lose any sleep over it.
400HP, Damn that makes me a rice boy too. Always new that they filtered for shit, but though that they would make better HP, waste of $400, but it looks cool.
If your not after looks then go for the K&N or Hurricane filters, they are cheap provide good power and filter well.
See'ya:burnout:
ok thanks for your input people.
dumb question but are some filters louder than others? the reason i ask is that I went for a ride in an R31 with an RB20det the other day and I think it had a HKS filter. Anyway...it was much much louder than the ones I have now.
Im pretty sure its "works autos" old 31.
BoostedRB26,
In general the filters that don't filter as well will sound louder, so that is not a good thing to go for, mine is hell loud but will only filter things the size of a small child. Go for the hurricane's from Works, they do the job well, plus you'll save heaps of money for something else.
See'ya:burnout:
Boosted rb26 i dont think it is the filters that are lounder rather the setup on the car. When i had a pod filter on my car with the stock turbo setup the pod was very loud with all the woosh noises when you back off etc, now with the new big turbo and a different setup there is no noticable annoying noise coming from the filters, i think it is an rb20 thing with loud filters.
Actually I do think the noise is to do with the filter and maybe the engine. A friend with an RB20DET + HKS pod is VERY loud. Then again Franks' car with RB25DET NEO + Apexi is very loud too.
In general all aftermarket filters are loud. When looking at the link I sent before the best for performance and filtration were the K&N and the Apexi.
I have a Trust Airnx filter, and it is one of the foam type filters. It does a good job of keeping out pebbles and small stones, but i'm convinced that it lets anything smaller than that through. It is damn loud, wooshing and fuffling like a mad dog.
I had a K&N on my old car, and it was a much more pleasant sound - deep and tough sounding intake and probably filtered alot better... thinking of changing back to a K&N,
I read somewhere on the UK GTR forum that that test doesn't prove much as there are other variables that weren't taken into consideration. I'll try to find it.
Here it is
Link
It is a long thread, but the Scott guy seems to know.
Silver-Arrowz,
I agree that most tests don't prove much in terms of power, but I do agree that most of the expensive Japanese brands tend to be pretty poor at small particle filtration. I like the look of my Blitz SUS, but if your after value for money then some of the cheap brands will filter much better and not affect power for about $25.
So if your a rice-boy like me, then go the Jap brand, if your not and only concerned about power then go for the cheap pod.
See'ya:burnout:
Originally posted by 2fardown
Just get a K&N panel filter for your factory air box.  You won't be sucking in hot engine bay air and they filter a lot better.  Plus you can't get defected for it.
Absolutely.
For the 32R , the gains in a pod filter over a good K+N panel filter are zero unless you pushing big HP and there is some sort of cold air box .
Only thing pod filter gives is the blowoffs are heard which may or may not be a good thing.
Sounded good on mine for about... ohh... 5 minutes then started getting annoying.
Cheers
Ken
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
