Not really sure; from what I can see its pretty straight forward whats going on.
When the FPCM receives the signal from the ECU the the voltage earths directly.
When the FPCM doesn't receive the signal from the ecu the earth passes through the dropping resistor.
The GTR is essentially identical apart from the FPCM containing the dropping resistor and receiving 2 signals from the ecu to determine if the fuel pump is high or low.
The voltage reduction isn't an issue, thats easy to understand, more that I was just wondering what the 'air regulator' that is on the load side of the fuel pump relay actually did.
  • 4 weeks later...
I am sorry to hijack your thread but it seemed easier than starting a new one. I have an r32 GTST with some mild mods (hi-flow,etc). I am wondering, is there any advantage in re-wiring the stock pump like this? & can I just earth out a wire rather than replace everything. If so, which wire? I am just after a slight increase until I fit a new pump. Am going to go & check voltages now. Will post them up when found
The problem is the + feed; earthing to the chassis does increase voltage slightly but when the pump is working hard against high fuel pressure (base pressure + boost pressure) voltage drops as the std wiring cannot handle the current draw.
Does anyone know whether ecu pin 104 earths or gives a 12v trigger to switch the fpcm to direct earth?
  • 7 months later...
  • 3 weeks later...
From what i have read and understood is that the standard 12v turns the relay on so the constant 12v from the battery flows to the pump.
Also i had an amp in my boot at on stage and the wires are still there just not hooked up to the battery could i use that wire i carnt remember what gage it is but is pretty big.
Cheers
  • 4 weeks later...
Other than weight there's not really any downsides to using overkill sized wire.
Why not use something a little more sensibly sized and used to the existing chunky wire as your draw cable?
i.e. Tape the new wire to old, and pull it thru.
I had a bit of time on my hands this week.
I swapped my r32 gtst pump over to a r32 gtr pump and decided to do the wiring upgrade.
After reading this thread through I used the schematic from the thread and traced all the fuel system wires in the car with a multi meter and found the fuel pump control modulator and factory relay in the boot. I also located the dropping resistor for the low speed in the enginebay.
This process has shown me how the system works but there is one thing about the system I still don't understand.
The black/yellow wire that is the power from the factory relay to the fuel pump and also supplies power to the fpcm but then for some reason runs back into the loom toward the front of the car.
The schematic doesn't show this.
What does it do?
Has anyone got an actual wiring diagram?
  • 4 weeks later...
Just wondering if this mod poses any safey concerns relating to the fuel pump safety shut off (ie, event of an accident)? Or is it totally unrelated?
It does actually bypass one safeguard.
The power to the factory relay is switched by ignition so even if the relay fails and locks on the pump will only run when the ignition is on.
With this mod if the relay locks on the pump will run regardless of whether the ignition is on or off.
Easy fixed... run another relay that is activated by the ignition switch. As per factory.
I'm really not worried about it.
With the factory setup...
Your in an accident and for what ever reason the factory relay fails the system will still run until you kill the ignition.
If the factory relay were to take a hit and some how weld on chances are it would short the wires attached so its unlikely the fuel pump would run.
If the relay were to weld on under normal conditions; you turn the car off WTF the fuel pump is still running. Some things not right with that I'd better fix it. :P
I believe its unlikely to become a problem. Sure it doesn't meet ADR's but hell it doesn't anyway nor does that bigger turbo or rb30 sitting under the hood. :S
  • 1 month later...
well.. i did the mod on my car today, but i re wired it all the way to the fuel pump itself. but i t still didnt fix my problem. Though.. i did notice my injector duty cycle did increase dramatically after doing this mod.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
