ok i just read every post in this thread and im more confused than ever.....does someone have photos or a diagram showing what has been done.....i get that you run power cable from the +ve batt to the relay to the pump, and ground the pump to the chassis.....then how do i wire up the oem pump wiring to the relay? oem +ve to +ve on relay? then oem -ve to relay then -ve on relay to chassis or oem -ve straight to chassis.....hope this makes sense :D
Cheers
Yeh, I don't have a clue what's going on either.
Relay connections...HUH :P ???
This is a diagram I made...from what I've done so far. Any mistakes...
I really need to know what to connect on the relay and where to connect it?
use the original positive feed wire to the pump as the positive trigger for the relay.
a relay is composed of two parts; a coil, and a switch.
so.. you use the positive wire from the original pump installation, onto one side of the coil
then you earth the other side of the coil to chassis. so if the car says for the pump to go, the relay clicks and switches over.
then.. you attach you new big beefy power feed to one side of the switch section.
and then attach the wire from the othe side of the switch section, on a contact that is normally open circuit, to go to your pump psitive terminal.
bingo pumpo working.
therefore, your pic is ok, just needed to add the trigger wire (from original wiring) and work out which terminals are coil, and which ones are the open circuit switch.
look here --> http://www.traxide.com.au/Relay_Info.html for relay terminal piccies and descriptions..
remember, you want to use the contacts that DON'T make a circuit until the coil is activated.
hope that helps.
james.
Edited by heller44
Uhh ok..still clueless!
Maybe I should buy the relay from Jaycar first...
Are there many terminals on it or just the 3...Switch Earth and Positive
Care to elaborate A LOT LOT Deeper for a stupid guy like myself.
ie. terminals...WHAT wire goes WHERE, and in what TERMINAL!!!
I'm a 1st yr Electrician so i know basics, but not that far!!
OK..
So this is it then in the drawing right...
So the positive that was originally goes to the pump goes into the Relay to activate the Coil and turn on.
But how does this Bypass the original Relay used as that is what i wanna do.
I want to re-wire the pump switch, where do i get that switch wire from?
This is for an R33 by the way?
Cheers
Simple. Don't care about modifying the previous install. Still use it to trigger the new circuit as then you will keep all the safety side of it with the ecu controlling the pump turn on and turn off. Use the lil wire that used to go to the positive on your pump to instead go to your coil on your relay.
Even if you lose a volt or two in the run of cable, the relay will still switch reliably as it only needs about 4 volts minimum to pull in.
Don't touch any more of your previous wiring other than taping up or otherwise removing the original pump negative wire. That one is no longer needed.
  • 3 months later...
just a question...
im gonna do this weekend. i read a few pages back someone asking the question "how is the new wiring run from the fuel pump itself to outside the tank?" how has everybody done this? i was thinking of making up a plug of sum sort and trying to use the stock connections on the cap to the fuel tank. but finding empty plugs that are compatible with those sockets are hard to come by, and by that i mean i cannot find any. so how has everybody done this?
uploaded a diagram of what i am going to do electrically but am still undecided on how to get the power into the tank for the pump
any ideas or suggestions would be appreciated
Are you asking about the feed to the pump itself or inside the tank for an aftermarket pump? Outside just twitch and solder and heatshrink the lot. Inside you can do the same but I am unsure that heatshrink will last immersed in fuel. I used crimps done properly.
Edited by heller44
both actually...
what i have done is wired up the "power" side of my relay unit in 6mm2 wire. im gonna mount this next to the other relays next to my battery in the boot. signal wire coming from the ECU obviously goes to the standard relay which is already next to the battery. so what im doing is taking the signal wire from that, using it to energise the coil for the fuel pump relay and using the relay to switch the fuel pump on and off like the stock wiring does... thats all sweet... what i would like to know is how ppl have run their wiring from their relays, into the fuel tank to the aftermarket pump...
pump btw is a bosch 040
When i did my install.. i fed the larger positive wire all the way to the fuel pump itself. I also upgraded the earth wire from the pump to chassis. the only thing i had to do was increase the hole size's on the pump bracket inside the tank for the new wire to fit in. It's easy to do and should really be done i believe.
Edited by mtopxsecret6
did this 2day. also installed my bosch 040 fuel pump aswell. i can honestly say im pretty happy with the results. and i can totally understand how some ppl get confused with the wiring. easy to draw on a piece of paper, a little bit confusing curled up in the boot of ur car. what i was having trouble with was integrating my relay cct into the 33's wiring system. i took quite a few pictures of what i was doing and ill upload them tmrw arvo/nite since im @ my gf's house atm.
if you can spare a few hundred $$$ and a saturday/sunday, id reccommend doing this install. i plan later on 2 get my 33 upto around 260-270rwks and having this mod installed in my car will help with this goal.
and btw, to all those ppl out there who rekn the pump is noisy? wtf r u's all talkin about? the only time i can really hear the pump is when i turn the car over from "ACC" to "ON". the pump runs for <3 seconds and thats it (priming the fuel lines mayb). driving in traffic i cannot hear a thing and at lights with the stereo off and just the sweeeeet noise of the RB engine humming @ 750rmp idiling, i can barely hear it.
I hope you soldered those crimps on the fuel pump, and did you run the large earth and positive wire through the original plug? so large wire's.. through original wire on plug then to large wire to pump? thats kind of only going to be as good as the original wire, it will be acting as a restrictor. Some might say it wot make much of a diference.. but.. why do the upgrade in the end if your going to retain some/part of the original wire?? It does look like a nice job, though i would modify those couple of points myself.
I don't see why he needs to solder the crimp connections, as long as he used quality connectors and a proper tool to crimp them.
Though you are correct in saying that the length of original wiring will act as a resistor, resistance is proportional to the length of the wire (as well as the cross sectional area), so considering the length of the original (smaller size) wiring looks like about 5cm, any difference in resistance would be negligible.
Using large diameter wiring all the way through the connector would require repinning the connector, which on some connectors can be a real PITA.
Edited by daisu
go around the connector. it has a rubber boot seal.. cut a slit and go through that way.. pull the wire out and the seal reseal's itself. The crimp provides mechanical strength for the connecion.. the solder provides electrical srength for the connection, being a vibratory piece of equipment.. it could, though may not, suffer from loosness, or tearing from the vibrations etc. Crimps are only the quick and easy option anyway. My dad being an ex electrician always taught me, my work must outlive the component im workng on.
Though it does look like a good job.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
