Is there anything that will be a major problem with splicing a set of series two coilpacks into a series one loom? I havn't had a close look at a series 1 loom yet, but I assume it's basically a matter of just skipping past the series 1 ignitor and hooking them in directly to the loom?
If anyone has done this I'd love to hear how it went.
https://www.sau.com.au/forums/topic/92241-replacing-ser1-coilpacks-with-ser2s/
Sorry buddy but it will not work.
Firstly, the series 2 coil pack will not fit into the series 1 steel brackets...different shape...series 1s are bigger. secondly, the series 1 coil pack has the ignitor inside each coil. In the series 2 coilpacks, the ignitor is outside the engine in the little black box somewhere near the fire wall.
So your car will not run with the series 2 coilpack in it.
Get yourself a set of splitfire coils from nengun.com like i did. Much better and worth the wait!!!
I know this bcos it has been mentioned on the forum b4 and also my mechanic tried to fit series 2 coils in my series 1 and it wouldnt even fit at all!!! Even if he did get it to fit somehow, it still will not work....haha...some mechanic :rolleyes:
If you compare a series 2 coilpack with a serie 1 coilpack, you will find notable differences...size, shape and colour(series 2 a bit more greyish).
Edited by danieltangtc
platinum - i can see no major problems with getting the series 2 coil bracket and coils, skipping the ignitor and wiring them in directly. i beleive it will work just fine. if you can't get the bracket though, just remote-mount them with leads on the firewall.
I think that will be okay as I have the series 2 steel brackets as well as the coilpacks. :D
I'll just wire in the series 2 loom plug (i have that too heh!) straight into where there series 1 loom usually goes into the ignitor.
Looks like a nice experiment but I think some magic smoke will be happening...
Just because it looks simple, doesn't mean it works that way. There are more things to consider. People who have experimented with their igition system have fried their coils, ECU, ignitor modules and so one.
Hope all works out but I wouldn't do it!!
I've heard alot of horror stories about igition systems so its your call, make sure you do alot of research first.
I don't know - but it seems to me that in series 1's is goes
Signal -> Igniter -> Coilpacks -> Sparkplug
Whereas, in the series 2's it simply cuts out the extrac jump and goes
Signal -> igniter/coilpack combo -> Sparkplug
The actual signal from the loom should be identical I'd say.
benl1981: how much are you chasing
N I B: thanks, any reason why they are better? ;)
I don't know if I should admit this.... :(
But I was just down having a play with the setup, and thought that the plug on the loom coming from the coilpacks looked a very similar size to the one on the ignitor, and what do you know it fits perfecty. ;)
Should really learn to check these things. :(
make sure the pins are correct and see how it goes.
interesting about the series 1 coilpacks being a bit better, anyone else found this?
NIB you mentioned using a GTR ignitor can help, is there much wiring and mucking around to do when installing one in place of the RB25 job?
    • Great interview on damper settings and coil selection by HPA https://www.facebook.com/HPAcademy/videos/30284693841175196/?fs=e&s=TIeQ9V&fs=e
    • Yeah, it was a pretty deep dig.
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
