Hey
Ive run into some trouble.. (1993 R33 GTS-T, NO engine mods)
Last night i was cruising around and all of a sudden it felt as if the engine 'grabbed', similar felling to pressing the brakes, there was no response from the accellerator so i backed off to around 60km and tried to accelerate again but nothing but a steady crawl... i realised there was no boost at all, no blow off valve noise, nothing!
I also noticed a horrid burning smell whenever i revved over 2500rpm, so i basically had to roll all the way home. I also noticed this morning that it is blowing white smoke out the back like a bitch, and still no boost.
I took it to the mechanix and left it with him, he rings me up and tells me the exhaust impeller wheel has desintegrated and parts of it have collected near the cat, so basically its rat-sh!t...
Now, i live in a area thats far removed from anything resembling an import wrecking yard (Outback NSW, near places like Orange, Dubbo, Bathurst) and need help finding a replacement turbo.
I have looked at buying a T3/T4, but would require a different wastegate, dump pipe, maifold etc so i have decided to try and locate a stock R33 turbo second hand (But in good nick) from somewhere, i just need help finding that somewhere...
Any help is greatly appreciated...
EDIT: Sorry... new
EDIT - R31Nismoid - legal reasons, no-one likes a bragger, illegal street activvities are not cool
Edited by ch0pstA~
https://www.sau.com.au/forums/topic/92250-blown-skyline-turbo/
bear in mind if you get a 2nd hand one it could do the same thing yours did within 6 months. HKS 2530 can be had for about 1200-1500 second hand. You only have to have water lines and oil lines modified slightly. You could sell your blow turbo to someone for probably 100 bucks which will cover the water lines and oil lines.
Otherwise get yours rebuilt. I wouldn't spend much more than 300 for a 2nd hand stocker due to the condition being a bit unknown
thats a bit steep. dont pay any more than $400 for one. there don't seem to be any for sale in the forums at the moment but try these 3 places.
http://www.option1garage.com.au
http://www.importbitz.com/turbo.htm
http://www.justjap.com/
Sorry i couldnt help more.
Dont pay that much!! Wait for one on the forums if you can. About $400 max would be the no.
Otherwise get a highflow for $2k..maybe ring up a turbo rebuilder..if you want just the same as stock but with a steel wheel on the exhaust you amy be able to get it a bit cheaper..
And how can you prove or say that the same thing wont happen to the 2nd hand HKS one aswell?
Just because it has a brand name does not mean that it didnt get a flogging, high km's and poor owner care which all lead to it blowing
I guess that's true about 2nd hand HKS - but atleast you don't stand the same chance of the wheel flying off. Shaft play can help give an indication
If 2nd hand HKS it would be nice to see a receipt or something - agreed if you spend that much on something 2nd hand it is a little iffy.
Well its my daily driver so i need it back on the road ASAP, i guess i may just have to go for the $650 one....
BTW, heres a photo of the culprit, all its done is cost me money since i got it... im considering looking around for a late R33 model with engine mods already done... we'll see... btw colour is Black with midnight purple pearl, beautiful in the sunlight...
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
