Greg: boot rattles... here we go hehehhe :) this the hardest area of any vehicle to stoff rattles and soundeaden :wave: there are a couple of options.....
1. put rubber matting in between the boot welds....
2. soundeadener in a can on the boot lid...
3. soundeaden matting on the boot lid...
4. after doing either one of these it looks cool to cover it up with a custom made interior panel to cover it over. not very expensive at all, hopefully that should fix it... it really is a common problem for any car.
by the way... screwing your number plate down with 4 screws (one in each corner) with a rectangle sheet of rubber matting behind it will stop your number plate from rattling almost completely :P let me know how it goes mate ;)
How to get rid of high pitched alternator noice once and for all ?? (I got it down to a bearable level, but is stil there)
Have tried the following :
Run RCA's and Power down seperate sides of the car -
Earthed the Amps as well as I can - (pretty farking good)
Tuned the amp hi pass and low pass filters as best I can.
Cheers,
brendanf: What it sounds like you need are some noise suppressors how many channels is the amp?
if it is four channels you will need 2 suppressors
if it is two channels you will need 1 suppressor
you can pick these up for $20-$25 from any decent audio store, they plug straight into your rca leads at you amplifier end :wave: let me know how you go brendanf
Originally posted by eliter33
Silver-Arrowz: hey man :wave: were you looking for the pro 3-way or 2-way components?
And yes i can get them  :)  they are an absolutely kick ass set of splits  :P highly recommended
I was looking at the 2 way. Had a listen to them, also the MB quartz and dynaudio. Boston sounds more warm.MB too sharp and dynaudio sounds a bit dull. They're not suited to my style of music.
i agree, the Bostons do sound warm and great  :P have you gotten any prices so far on them? when did you want them?   ;)
Best retail price I've got is 800. In about 3 or 5 months. I can get them now but no point since I've got no amp. I figured do both at the same time.
Silver-Arrowz
when you want them let me know. the focals are good too, i sell both; but i certainly know which i prefer, i would always go for the bostons, they have a really distinctive sound i think :D let me know either way :)
akeenan:
i didnt know anyone still used compression horns, i have a set at work but they are hard as shit to sell because it is hard to find the right person (let alone right car!!!) to fit them in hehehe :) horns are the bomb when it comes to quality in a lot of respects though :)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
