Hi all,
I've got all tomorrow off work, so i'll be heading out to WSID. I'll be at the gates at 4:45pm as i'd like to get in early.
If anyone see's me, feel free to come say hi.
I've just got a R33 GTS-T with an exhaust and Falken Ziex tyres, so i'm not expecting good times, but it will be good fun..
Hope to see some of you there ;)
Regards,
Tommo.
https://www.sau.com.au/forums/topic/92456-wsid-261005/
It was a pretty good night, although damn hot and humid, which my stock side mount didn't like too much at all.
Managed to get a 14.3 @ 96mph anyway.
R33 GTS-T with turbo back exhaust, 8psi, and falken Ziex tyres.
https://www.sau.com.au/forums/topic/92456-wsid-261005/#findComment-1669171
Not bad, do you have nails in both tyres as i saw both sparking? Im guessing these were 2nd gear burnouts.
How many runs did you get in?
Yeah 2nd gear burnouts... I think in the right one I just had a rock because that was the only time it did it... so dodgy though - so i've booked in to get new tyres on Tuesday :) Both tyres only spark in the first video (tommowsid.avi)
Managed to get 5 runs in, between 6pm and 8:30pm (at that point, my tyres were pretty much bald and it wasn't going to get any colder :))
I'd also gotten 96mph in EVERY one of my runs, just with a different 60ft time.. I figured the only way I was going to get faster is with a better MPH, which just wasn't going to happen.
Edited by TommO
https://www.sau.com.au/forums/topic/92456-wsid-261005/#findComment-1671348
Funny you say about 2nd gear burnouts, but i started doing these and on every occassion i couldnt grab 3rd gear on my run. I thought something is wrong with the box and i started to get quotes on a new gearbox. So next runs, i swapped back to only 1st gear burnouts and now i hit 3rd gear every time. Weird hey
https://www.sau.com.au/forums/topic/92456-wsid-261005/#findComment-1672727
I had no problems selecting gears throughout the run? Sucks to hear about that problem, I haven't experienced that though.
Wilch: I know what you mean, I read that too, so I played around with it myseld. In the end, the bigger burnout I did, the better 60ft I was getting. Thats the thing, the Falken Ziex's have a very very high temperature rating as to when they become sticky, and the big burnouts got them there :) I tried a little first gear burnout on my first run and it spun a lot off the line... :O
edit: I got a best of 2.100 60ft time.... not too great but not too shitty either :D
Edited by TommO
https://www.sau.com.au/forums/topic/92456-wsid-261005/#findComment-1673203
Believe me, a 2.1 60" on those rubbish tyres is pretty good. The best I could manage on the same tyres was a 2.2 with plenty of 2.3-2.5's in there for good measure. Whether I did a burnout or not didn't really make any difference to my times.
A set of sticky tyres would drop you into the 13's without any problems at all - they basically dropped me from a 13.7 to a 12.9 (with a few other small mods).
Back on street tyres though, what are you replacing the Falkens with Tommo?
I'm going to get rid of mine as well, just trying to get another opinion on what tyres to replace them with (was thinking either Toyo T1R's or Goodyear Revspec RS-02's).
https://www.sau.com.au/forums/topic/92456-wsid-261005/#findComment-1673570
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
