Hi all,
I've got all tomorrow off work, so i'll be heading out to WSID. I'll be at the gates at 4:45pm as i'd like to get in early.
If anyone see's me, feel free to come say hi.
I've just got a R33 GTS-T with an exhaust and Falken Ziex tyres, so i'm not expecting good times, but it will be good fun..
Hope to see some of you there ;)
Regards,
Tommo.
https://www.sau.com.au/forums/topic/92456-wsid-261005/
It was a pretty good night, although damn hot and humid, which my stock side mount didn't like too much at all.
Managed to get a 14.3 @ 96mph anyway.
R33 GTS-T with turbo back exhaust, 8psi, and falken Ziex tyres.
https://www.sau.com.au/forums/topic/92456-wsid-261005/#findComment-1669171
Not bad, do you have nails in both tyres as i saw both sparking? Im guessing these were 2nd gear burnouts.
How many runs did you get in?
Yeah 2nd gear burnouts... I think in the right one I just had a rock because that was the only time it did it... so dodgy though - so i've booked in to get new tyres on Tuesday :) Both tyres only spark in the first video (tommowsid.avi)
Managed to get 5 runs in, between 6pm and 8:30pm (at that point, my tyres were pretty much bald and it wasn't going to get any colder :))
I'd also gotten 96mph in EVERY one of my runs, just with a different 60ft time.. I figured the only way I was going to get faster is with a better MPH, which just wasn't going to happen.
Edited by TommO
https://www.sau.com.au/forums/topic/92456-wsid-261005/#findComment-1671348
Funny you say about 2nd gear burnouts, but i started doing these and on every occassion i couldnt grab 3rd gear on my run. I thought something is wrong with the box and i started to get quotes on a new gearbox. So next runs, i swapped back to only 1st gear burnouts and now i hit 3rd gear every time. Weird hey
https://www.sau.com.au/forums/topic/92456-wsid-261005/#findComment-1672727
I had no problems selecting gears throughout the run? Sucks to hear about that problem, I haven't experienced that though.
Wilch: I know what you mean, I read that too, so I played around with it myseld. In the end, the bigger burnout I did, the better 60ft I was getting. Thats the thing, the Falken Ziex's have a very very high temperature rating as to when they become sticky, and the big burnouts got them there :) I tried a little first gear burnout on my first run and it spun a lot off the line... :O
edit: I got a best of 2.100 60ft time.... not too great but not too shitty either :D
Edited by TommO
https://www.sau.com.au/forums/topic/92456-wsid-261005/#findComment-1673203
Believe me, a 2.1 60" on those rubbish tyres is pretty good. The best I could manage on the same tyres was a 2.2 with plenty of 2.3-2.5's in there for good measure. Whether I did a burnout or not didn't really make any difference to my times.
A set of sticky tyres would drop you into the 13's without any problems at all - they basically dropped me from a 13.7 to a 12.9 (with a few other small mods).
Back on street tyres though, what are you replacing the Falkens with Tommo?
I'm going to get rid of mine as well, just trying to get another opinion on what tyres to replace them with (was thinking either Toyo T1R's or Goodyear Revspec RS-02's).
https://www.sau.com.au/forums/topic/92456-wsid-261005/#findComment-1673570
    • Or the brand new throwout may be unhappy...
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
