Item inmber 3 is already sold
1,2,4,5 still available ;)
cheers
Just sold number 5 as well...
only 1,2,and 4 left... and i have interest in all three. so if you want one please post that you will take it below in this thread and PM me your phone number:)
cheers guys.
Edited by CEF11E
would these be good enough to run the autronics or whatever engine ecu programs to tune? the ecu programs only a dos load of shit so i think it would be ok, might be interested.
r u willing to ship to perth if i pay postage?
can u send a PM reply please
cheers
Brad
  • 4 weeks later...
CEF11E,
I'm interested in:
4 x IBM 765D (selling for $100 each)
72MB ram
3GB hard drive
CD rom
13.1 TFT screen
Couple of Q's: Do these have a USB port ? Are batteries available for these ( and charger ) ? Will this run NISSAN Datascan well ? ( the real reason I need it )
Cheers.
P.S. I'm in Sydney.
